Car Bucking
isuras2
PostPosted: Tue Sep 07, 2010 2:57 am    Post subject: Car Bucking Reply with quote
While driving the car, under regular to hard acceleration, the car starts bucking. It happens all the time, meaning acceleration while going slow (20 mph) or fast (60-70 mph). Any suggestions?
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Tue Sep 07, 2010 4:19 am    Post subject: Reply with quote
Most likely, the lower charge tube bracket has gone missing and the lower charge tube is lifting off of the turbo outlet under boost.
isuras2
PostPosted: Tue Sep 07, 2010 5:03 am    Post subject: Reply with quote
I read this thread about checking the charge tube, but it didn't move separate from the turbo when I shook it.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Tue Sep 07, 2010 6:30 am    Post subject: Reply with quote
Would you rate it as a light bucking, or as severe bucking?
Severe bucking - like it might throw you through the windshield if your seatbelt wasn't on, could be caused by a torn wastegate diaphragm. This allows boost to build too high, triggering the overboost cutoff switch which shuts off the fuel pumps, and you get a sudden decelleration.
Light bucking, I believe can be caused by incorrect A:F mix - too lean is it?..
isuras2
PostPosted: Tue Sep 07, 2010 7:46 am    Post subject: Reply with quote
I would rate it as more severe, especially under heavy acceleration. How easy it is to check the wastegate diaphragm?
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
PostPosted: Tue Sep 07, 2010 12:36 pm    Post subject: Reply with quote
This could be a fuel delivery problem. . .check pump volume per FSM.
In answer to your query, you should be able to use a hand pump on the control line to actuate the wastegate (no more than 10 PSI or so), and it should hold pressure. . .forever. If it doesn't, post back for a hardware list to pull and refresh the waste. ASS! PAIN!
