sparky
Posted: Fri Sep 03, 2010 8:57 am Post subject: Sticking brakes |
Hey guys.
So the 951 brake/suspension upgrade was working great until I went to get the wheels all aligned. They put some bar on the brake pedal to hold the brakes down while they were doing the wheel alignment, im not sure if it is coincidental or if it effected something but ever since, if i go for a drive now, all the brakes seem to jam on after about 10 mins of driving and braking. It gradually gets worse during the drive until the brakes are jammed on too much to even drive.
If I leave the car for a while, the brakes release and the same happens again if i go for another drive. If i dont touch the brakes, they dont seem to jam.
What could cause this problem?
The car has a 951 brake/suspension upgrade with a 951 MC and Booster.
Mark _________________ When the checkered flag drops... The Bull$hit Stops
1976 Euro 924 (The 945) - Full 951 Brakes/Suspension
1998 Boxster with goodies
2002 3.0 Xtype 4wd sport |
Posted: Fri Sep 03, 2010 12:54 pm Post subject: |
How old are the brake hoses and master cylinder?
The lines could be collapsing internally. _________________ Stefan
Posted: Fri Sep 03, 2010 1:17 pm Post subject: |
sticking calipers?
were these new or refurbished? _________________ Porsche 924 1984 (UK import) NA
daniel
Posted: Fri Sep 03, 2010 1:49 pm Post subject: |
Had this problem once with a Formula Vee, tiny metal filings in the fluid due to the master cylinder running off square. Blead a little fluid of each caliper and see what it looks like _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
ic932
Posted: Fri Sep 03, 2010 7:16 pm Post subject: |
+1 on the flexi-hoses collapsing internally, if old...
Brembos of this type can suffer "plate-lift" The stainless plates that the pads ride on get warped due to corrosion developing behind them (alloy - steel - bad reaction)
The quick fix is to shave a mm or two off each side of the pads' steel backing plate to loosen them up.
The proper way of course is to remove the plates and scape away the gunk the replace with new ones.
Always heat the allen bolts that hold the plates on until they are cherry red, they are tight and locktited too! |
sparky
Posted: Fri Sep 03, 2010 7:31 pm Post subject: |
Hey guys,
The Flexi hoses are brand new and the calipers are newly refurbished. All the brake lines are new on the car.
Its not 1 brake that is sticking on after some use, its all the brakes equally jamming themselves on. I went to a test run this morning, after about 10mins they started to apply a little and after then when i braked it was just getting worse until it was hard to pull into the drive. I just went out now (2hrs later) and they are completly free again.
I had the problem of the metal backing warping on my xtype but that made more of an annoying squeeking sound and no noticable brake force, this is more like someone is putting reasonable force on the brake pedal.
When this happens the brake pedal is stiff as a rock right at the top.
Considering all 4 wheels are locking up at the same time, its hard to imagine it being related to a sticking caliper or a collapsing hose isnt it?
Hopefully the above info helps shed some light onto this
Thanks,
Posted: Fri Sep 03, 2010 8:15 pm Post subject: |
check your vacum one way valve...maybe you've installed it backwards? _________________ Supercharger and EFI kits
sparky
Posted: Fri Sep 03, 2010 8:23 pm Post subject: |
Hey buddy,
Checked/Tried.
The first time this happened I thought there may have been a vacuum lock and undid the vacuum hose but it made no difference. The brakes use to work fine with no issues until I went to the wheel alignment guy. Im guessing this was just coincidental.
This is really weird. _________________ When the checkered flag drops... The Bull$hit Stops
Joined: 29 Jul 2001 Posts: 9131 Location: Royal Oak, MI, USA
Posted: Fri Sep 03, 2010 9:36 pm Post subject: |
Then the next remaining weak point would be the master cylinder sticking. Perhaps you'll need to rebuild it? Would make sense, as the alignment guy probably pushed it down further than you normally do when driving. _________________ Vaughan Scott
Posted: Fri Sep 03, 2010 9:43 pm Post subject: |
| 924RACR wrote: | | Then the next remaining weak point would be the master cylinder sticking. Perhaps you'll need to rebuild it? Would make sense, as the alignment guy probably pushed it down further than you normally do when driving. |
1+ check the master cyl...maybe it needs cleaning...rebuilding. _________________ Supercharger and EFI kits
sparky
Posted: Fri Sep 03, 2010 10:37 pm Post subject: |
Aight ill get onto taking it out tomorrow. What should I be looking for when its out and taken to bits?
Do you think a good cleaning will do the trick, I cant seem to find any master cylinder rebuild kits. Im guessing it is all dependant on what condition the bore/piston is in.
Many thanks for the pointer,
Posted: Sat Sep 04, 2010 1:07 am Post subject: |
Since you swapped your master cylinder and booster, I am wondering if your brake actuating rod is adjusted correctly.
Go under the dash, and undo the locking nut at the pedal. Then back out the rod, and screw it back in BY HAND until you can just feel it touch the cup it rides in inside the master cylinder.
Good luck! _________________ Toofah King Bad
Posted: Sat Sep 04, 2010 1:38 am Post subject: |
As Rasta says, it sounds as though your master cylinder isn't returning to the full "off" position.
When the master cylinder is in the full pedal up position, fluid can flow past the pistions. When you apply the brakes, this passage is blocked off so that the pistons can build pressure.
This bypass is there so that as the fluid heats up and expands, it can go into the brake fluid resivoir.
If your master cylinder never returns to the full "off" position, as your brakes heat up, they'll apply more and more as the expanding fluid builds pressure.
You'll have problems bleeding your brakes without this adjusted properly too. _________________ 78 924 NA
5-lug |
sparky
Posted: Sat Sep 04, 2010 5:52 am Post subject: |
Cheers guys!
Ill get onto this at first daylight tomorrow and let you know how it goes!
This does make perfect sense though  _________________ When the checkered flag drops... The Bull$hit Stops
sparky
Posted: Sun Sep 05, 2010 10:36 am Post subject: |
Fiiiiiiiiiiixed
What seems to have happened is the metal which the brake pedal rests against when the brake is not pressed got bent forwards, most likely from the wheel alignment guy paying no attention to where he put the thing that holds the pedal down. It was causing the problem that you guys described with the piston not fully retracting.
Ive bent it back up and there seems to be no problem at all now
Next up is fixing a few electrical gremlins and "the man" is coming round at the end of the week to sort that side of things out
Its finally a car!
I will take it to a bodyshop next time im abroad for a while and get them to reduce the size of all the gaps in the body panels, mainly the boot area, wings and hood. The sunroof is pointless and annoying, its too hot here to ever open it up. Considering a delete on that too.
So I dont start a new thread, are there any upgraded alternators I can run on the car that are an easy swap? When my lights are all lit up and my amp is on, it falls to 11v
Thank you all so much for help with the brake problem! _________________ When the checkered flag drops... The Bull$hit Stops
