Ground Control Camber Plates
PostPosted: Tue Aug 24, 2010 1:16 am    Post subject: Ground Control Camber Plates Reply with quote
Any opinions on the quality of these bits? They are currently on sale on the GC website quite cheap.
PostPosted: Tue Aug 24, 2010 2:08 am    Post subject: Reply with quote
I believe they're essentially the same as the Paragon ones I've been running for years...
PostPosted: Tue Aug 24, 2010 2:41 am    Post subject: Reply with quote
Nice site.. Theres the the whole racecar sus. setup 4
$1999.00. Its nice though theres other ways to go Im sure..
& Id b willing 2 say theyve sold alot of those.
Thanks 4 the site bigman.
macBdog
PostPosted: Tue Aug 31, 2010 4:30 pm    Post subject: Reply with quote
Are the ebay nasty ones that much worse than the GC's? I'm about to buy all the bits and pieces to convert my stock M474 suspension to coil overs, spring perches and camberplates and was going to use the ebays. Ground Control's look better...
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways
PostPosted: Tue Aug 31, 2010 11:43 pm    Post subject: Reply with quote
Lots of people complain about the Mookeh bearings binding. . .I was tempted but decided to stay away from them.
PostPosted: Wed Sep 01, 2010 12:56 am    Post subject: Reply with quote
GC have a roller/needle bearing for axial loads, thumbs up for that !
PostPosted: Wed Sep 01, 2010 1:05 am    Post subject: Reply with quote
Yes, and this is what the Mookeh plates lack. The bearing in them is much smaller and cheaper. There have been conflicting reports (mostly on Rennlist) re: their longevity. Some have claimed no problems (although most indicated that they continually lubricated the bearing), while others have reported that the bearings are prone to seizing and failing.
The Ground Control units are really very nice, but are ~2x the cost.
IMO, the Mookehs are probably OK for occasional track use provided you lubricate the bearings regularly. If you're going to track the car regularly, I don't think there's much question that the GC units are the way to go.
macBdog
PostPosted: Wed Sep 01, 2010 10:17 am    Post subject: Reply with quote
Good call. Going with the GC's.
1973 911E with EFI
Tam Lin
PostPosted: Wed Sep 01, 2010 6:04 pm    Post subject: Reply with quote
Been using GCs on our sh!te roads in Britain for two years now, plus track days: recommended.
The Lindsey ones I had before were mashed to a pulp pretty quickly.
genikz88
PostPosted: Fri Dec 17, 2010 11:45 am    Post subject: Reply with quote
GC stuff is very good. Three years now on those plates with no isues whatsoever.
Chris
'88 924S
PostPosted: Fri Jun 03, 2011 1:24 am    Post subject: Reply with quote
To answer my own query, these things are awesome. Very well designed. . .NO load on the little top bearing, which only functions to locate the strut top.
The sale price is still on, so HIGHLY recommended.
CAVEAT - likely to raise front ride height, so should be used with lowering springs or coilovers.
