Dutch924-racer
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Mon Aug 30, 2010 3:58 am Post subject: Problems with fitting Dansk exhaust |
I have bought a Dansk exhaust for my 924 turbo.
The Dansk has fitting at the rear silincer for the later type of mounting. On my 931 (1979) I have the early type of mounting with the clamp around the silencer.
The problem is that silencer of the Dansk is much smaller then te original damper, so the clamp is way to big.
Does anybody had the same problem ?
Number 12:
 _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Forge recirculation valve + boost controller |
9xx
Posted: Mon Aug 30, 2010 4:11 am Post subject: |
Yes I had the same problem. Also the clamp would continuously drop of from its hanger (part number 11) with Dansk exhaust. I ended up drilling two holes to both hanger and clamp and then bolted them together. But it is only a temporary solution because as you said, the silencer is too small for the clamp and therefore rattles annoyingly.  _________________ Mikko
Posted: Mon Aug 30, 2010 4:23 am Post subject: |
Yup been there doner that. I got rid of alot of stuff... maybe to much..
I utilized what was offered and bought more parts. Another of these helped hang it. From the list part #19 and 20 and 17. All replaced
parts # 12 and 10. Though you could modify number
if you cut and weld.
Cheers. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Dutch924-racer
Posted: Mon Aug 30, 2010 4:48 am Post subject: |
there must be a clamp from another brand car that will fit................ _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Posted: Mon Aug 30, 2010 5:44 am Post subject: |
Im sure of it. Its time to look around _________________ 1979 porsche 924 Na
Posted: Mon Aug 30, 2010 7:06 am Post subject: |
Odd. My Dansk muffler came with a clamp and fits perfectly on the factory hanger setup. Mind you, this is on SONIC, an 81 NA, not a 931...was there a changeover between 79 and 80 on the muffler hanger setup??? _________________ erstwhile owner of just about every 924 variant ever made |
moorepower
Joined: 21 Dec 2006 Posts: 263 Location: Raleigh, North Carolina, USA
Posted: Tue Aug 31, 2010 7:58 am Post subject: |
Yeah, the Dansk on my '81 has a much smaller clamp than the stock one. The new exhaust should have come with one.
Of course my system was bought about 3 years ago. Maybe they stopped including the clamp? _________________ Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways |
Dutch924-racer
Posted: Thu Sep 02, 2010 5:29 am Post subject: |
Was the Dansk clamp also stainless ? _________________ 937 trackday car
Series 2 engine
Fast road camshaft
moorepower
Posted: Thu Sep 02, 2010 7:13 am Post subject: |
Yes, mine was stainless. _________________ Dan.
