Problems with fitting Dansk exhaust
Dutch924-racer
PostPosted: Mon Aug 30, 2010 3:58 am    Post subject: Problems with fitting Dansk exhaust Reply with quote
I have bought a Dansk exhaust for my 924 turbo.
The Dansk has fitting at the rear silincer for the later type of mounting. On my 931 (1979) I have the early type of mounting with the clamp around the silencer.
The problem is that silencer of the Dansk is much smaller then te original damper, so the clamp is way to big.
Does anybody had the same problem ?
Number 12:
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
9xx
PostPosted: Mon Aug 30, 2010 4:11 am    Post subject: Reply with quote
Yes I had the same problem. Also the clamp would continuously drop of from its hanger (part number 11) with Dansk exhaust. I ended up drilling two holes to both hanger and clamp and then bolted them together. But it is only a temporary solution because as you said, the silencer is too small for the clamp and therefore rattles annoyingly.
Mikko
PostPosted: Mon Aug 30, 2010 4:23 am    Post subject: Reply with quote
Yup been there doner that. I got rid of alot of stuff... maybe to much..
I utilized what was offered and bought more parts. Another of these helped hang it. From the list part #19 and 20 and 17. All replaced
parts # 12 and 10. Though you could modify number
if you cut and weld.
Cheers.
Dutch924-racer
PostPosted: Mon Aug 30, 2010 4:48 am    Post subject: Reply with quote
there must be a clamp from another brand car that will fit................
937 trackday car
Series 2 engine
Fast road camshaft
PostPosted: Mon Aug 30, 2010 5:44 am    Post subject: Reply with quote
Im sure of it. Its time to look around
PostPosted: Mon Aug 30, 2010 7:06 am    Post subject: Reply with quote
Odd. My Dansk muffler came with a clamp and fits perfectly on the factory hanger setup. Mind you, this is on SONIC, an 81 NA, not a 931...was there a changeover between 79 and 80 on the muffler hanger setup???
moorepower
PostPosted: Tue Aug 31, 2010 7:58 am    Post subject: Reply with quote
Yeah, the Dansk on my '81 has a much smaller clamp than the stock one. The new exhaust should have come with one.
Of course my system was bought about 3 years ago. Maybe they stopped including the clamp?
Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways
Dutch924-racer
PostPosted: Thu Sep 02, 2010 5:29 am    Post subject: Reply with quote
Was the Dansk clamp also stainless ?
937 trackday car
Series 2 engine
Fast road camshaft
moorepower
PostPosted: Thu Sep 02, 2010 7:13 am    Post subject: Reply with quote
Yes, mine was stainless.
Dan.
