Posted: Wed Aug 18, 2010 11:26 am Post subject: Got Webers? What accelerator cable are you using? |
If you have Webers you already know the stock accelerator cable will not work -- too short. So I was hoping someone could give me a source, manufacturer and most importantly a part number for the cable they're using.
I've heard Lokar but don't know what part # to order...
TIA |
the_mad_electrician
Posted: Wed Aug 18, 2010 11:58 am Post subject: |
I'm using the stock cable and the stock mount. its just somethign for temp but it works. _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Joined: 29 Jul 2001 Posts: 9103 Location: Royal Oak, MI, USA
Posted: Thu Aug 19, 2010 12:33 am Post subject: |
I've been looking into this for throttle and shifter cables for my DSR... here's some resources:
http://www.flanderscables.com/FlanCableSearch.html
They sell DIY parts you can assemble your own.
These guys don't have much on their website, but I just got their catalog yesterday, and I'm sure they can make anything you need!
http://www.push-pull.com/ _________________ Vaughan Scott
Posted: Thu Aug 19, 2010 2:16 am Post subject: |
Thanks guys. I appreciate the suggestions. Keep em coming.
I wish I knew what I was looking for. Then I could probably spec what I need at one of those build-your-own sites. But I was hoping someone could give me a lokar part # or something and I could just order it. I'd have to pay my guy $85/hour to spec $10 worth of cable and fittings, and that's not good economic sense at this point if you know what I mean... |
Posted: Thu Aug 19, 2010 3:15 am Post subject: |
I'll look at the Lokar cable I have and see if I can remember the part number. I've not gotten it completely installed yet, but it looks to be more than long enough to work with the linkage on my throttle bodies. _________________ Stefan
Posted: Thu Aug 19, 2010 4:45 am Post subject: |
| Yeah, if you could get a part # and post it, that would be SUPER! |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Tue Aug 24, 2010 12:40 am Post subject: |
hey emoore does your throtle lever pull straight down.im going to be useing a fulcrum to make mine work just making it now.pretty simple outfit.kinda of a bellcrank.it has 2 arms in the shape of a v,well a little wider than a v .the lower arm is longer than the upper arm.it will mont on the intake that bolts to the head.then i will be able to use the stock cable,it will pull the upper arm ,inturn the lower arm mounted in the pivot will pull straight down and full open my carbs.been messing with this all summer.makeing and remaking.im dam close now.still some adjustments.then it will go to be made of billet aluminum.that will cost!!! _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Posted: Tue Aug 24, 2010 2:41 am Post subject: |
Take a look over at the "before and after" thread. I have a solution but I'm not sure if its what I'll be using over the long term.
Still hoping for pics and part #s if anyone has them... |
Posted: Tue Aug 24, 2010 2:48 am Post subject: |
I would be looking at the Diy site posted dude, paragon has a really full catalog too. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Fri Aug 27, 2010 2:34 am Post subject: |
Jegs sells 'em too - www.Jegs.com. _________________ Vaughan Scott
