Bead Roller DIY
leadfoot
PostPosted: Wed Aug 18, 2010 8:34 pm    Post subject: Bead Roller DIY Reply with quote
saw this whilst searching the Internet,
pretty cool thinking, and seeing as most people have a vice in the workshop....
now if someone with a lathe wants to send me some dies??
RC... Scorps... come on buddies share the magic....
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
Rich H
PostPosted: Wed Aug 18, 2010 8:42 pm    Post subject: Reply with quote
You, sir, are a genius
PostPosted: Wed Aug 18, 2010 9:49 pm    Post subject: Reply with quote
Cool!
bnoon
PostPosted: Wed Aug 18, 2010 11:04 pm    Post subject: Reply with quote
Making the dies are cool, but how would you power the sheet metal through it once it's pinched in the vice???
'80 924 Turbo - SOLD!
1986 Porsche 944 Turbo - SOLD!
Porscheless
RC
PostPosted: Thu Aug 19, 2010 12:22 am    Post subject: Re: Bead Roller DIY Reply with quote
Stu
Thats a cool idea Stu. Vice will have sufficient pressure, no worries. Usually only a 1/2" thumbscrew to wind down on commercial machines. What you got in mind, - ends of the boost tubes?
Recall seeing a set of beading rollers around somewhere, in a mates workshop in Coffs I think. Could turn some up if theres no rush but too busy ATM. Will do it tomorrow though in exchange for a 22 x 31 seal thats NLA from Porsche, after a 2 week wait.
Pity it wasn`t a guard roller, looking into that ATM. That and more offset!
Easiest way would be manually with a crank handle fixed to the inner wheel.
Rich H
PostPosted: Thu Aug 19, 2010 12:40 am    Post subject: Reply with quote
I'd probably make one hole in the vice a plain hole and secure the bolt to the roller with the plain bore, once the rollers are enguged they won't move about adn then you can just use a ratchet or rattle gun.
Mike9311
PostPosted: Thu Aug 19, 2010 1:37 am    Post subject: Re: Bead Roller DIY Reply with quote
Stu
Many years ago I built a bench mounted bead roller but I have to say that is a really nice idea. Brilliant in its simplicity
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
bnoon
PostPosted: Thu Aug 19, 2010 3:18 am    Post subject: Reply with quote
I've been searching the net for more homemade bead rollers. Tons of others out there too, especially on rat rod and traditional rod sites, but here's one from a Honda site of all places. Looks really well made.
http://www.honda-tech.com/showthread.php?t=2710881
Porscheless
macBdog
PostPosted: Thu Aug 19, 2010 9:54 am    Post subject: Reply with quote
Hey RC, I'd def be up for a set if you were going to turn some up.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways
leadfoot
PostPosted: Thu Aug 19, 2010 8:46 pm    Post subject: Reply with quote
I think the easiest way is to just manually position it as you work the groove around the pipe,
another option would be to drill a couple of holes in the near side roller and use a crank similar in design to the timing belt tensioner
RC no rush mate, steel ones would be cool too...
actually thinking about it, alu one's would be cheaper to ship... and probably do the job quite well, see what you got lying around as stock mate...
S.
RC
PostPosted: Fri Aug 20, 2010 2:09 pm    Post subject: Reply with quote
Mild steel would be the go for occasional use on aluminium tube. Materials would be half the cost of ally and considerably more durable. Have`nt got any 50 - 65mm bar just lying around, would have to buy it and pay a premium for a short cut length.
These bead rollers often have the rollers designed for <1mm material, as they are commonly used on thin 0.4 or 0.6mm galvanized mild steel sheet for air conditioning duct work. So assuming you`re doing aluminium tubing would ideally want clearance for 1.6 - 2.0mm. I like the profile as shown on that link to the Honda site. Nice construction, workmanship and result.
If you and Mac are serious, come up with a basic design & dimensions and I`ll see if / when I can squeeze it in, but it won`t be soon.
This one on ebay is nearly over. The last one went for $300. Seller is where I bought my lathe, hydraulic press and some other tooling, so can recommend. Perhaps you SEQ boys can get a tool co-op happening?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=380258189513
Sleykin
PostPosted: Mon Aug 23, 2010 4:12 am    Post subject: Reply with quote
I have the one from harbor freight but it would be a 2 person job to use it on a tube.
http://www.harborfreight.com/garage-shop/metal-shaping-equipment/18-inch-sheet-metal-fabrication-kit-34104.html
Glenn Neff
Medford, OR
87' 924S
bnoon
PostPosted: Tue Aug 24, 2010 1:10 am    Post subject: Reply with quote
The one from HF can be used on aluminum tubing with one person just fine. You can even brace it to make it work for heavier metal gauges, many people have done that per the web. I got a coupon a week or so ago for 50% off, but I just don't have the need to pop for one yet. I gotta be able to weld aluminum before I can get into bead rolling.
Porscheless
Sleykin
PostPosted: Tue Aug 24, 2010 2:03 am    Post subject: Reply with quote
Ok, if you have three hands it could be done easily with one person LOL.
One person can run the crank and guide the material, but it is awkward. I plan to put a motor on it before I use it again. I have a metal lathe so I can make some interesting dies for it. I used it mostly for flanging sheetmetal for patches and for cutting sheetmetal. I have a beverly shear now so it won't see much cutting anymore. I paid less than $70 for it when I bought it years ago.
I suppose with tube you could just roll it as you crank down on the spacing adjustment and not use the crank.
Glenn Neff
Medford, OR
87' 924S
PostPosted: Tue Aug 24, 2010 2:53 am    Post subject: Reply with quote
Youve been called a genius.
I know I should of bought that vice.
