Scorpio
Posted: Wed Jul 07, 2010 9:29 am Post subject: Spray gun |
juat awaiting postage cost confirmation then im gonna be buying my new spray gun to colour coat/clear coat the car
Sick of using cheap no brand guns with bad spray patterns
Iwata AZ3 HTE
Best good brand spray gun i could find for the price
was also looking at sata and devilbiss
Major benefit
1) 79-84% transfer efficiency
2)Iwata reputation
3) Only 7CFM needed!
4)around $160 aud delivered ($74 GBP to buy) one good thing about the pound being weak
http://www.anest-iwataeu.com/objects/documents/brochures/az3hte2_en.pdf
 _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
931Owner
Joined: 14 Feb 2009 Posts: 352 Location: Chicago NW Suburbs
Posted: Wed Jul 07, 2010 2:03 pm Post subject: |
For things like fit and finish... you're going to want to have quality gear.
This sprayer looks the bees knees and is a good price to boot. _________________ 1980 Turbo
-too many cars and too many motobikes |
Scorpio
Posted: Wed Jul 07, 2010 2:24 pm Post subject: |
my first sprayer was absolute crap..its best setting gave me a jelly bean shape pattern.. at first i thought it was me being new then i looked at the nozzles and they werent symmetrical!..one side was drilled way different to the other hence the bad pattern.
All reviews and recommendations on the net point to devilbiss, sata or iwata...then within those they point to things like the
iwata w400, devilbiss GTi and sata 90...all these guns are $400 up!!
mine is the healthy compromise
80% transfer efficiency more paint on car and less in my lungs/garage
im gonna spray my black suzuki for practice first that should help me dial in good settings and get use to the gun before hitting toofah _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Posted: Wed Jul 07, 2010 3:41 pm Post subject: |
maybe give some pics soom too. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Gracie
Joined: 29 Nov 2004 Posts: 35 Location: Alberta, Canada. T9W1S9
Posted: Sat Jul 31, 2010 3:40 am Post subject: |
I have to say that if you will be painting more than just your car, you'll want to invest in Devilbiss or Sata. Thats all we use at our shop and I have never had a problem. I know that they are not cheap but the saying that you get what you pay for is sooooooo true. I'm sure that you know what you're doing, however I recommend a seperate gun for clear coat. Let me know how it turns out. _________________ Working on cars is restful for they have neither conflict nor emotion.
Time with cars is never wasted, even if all you do is stand there and curse at the unfinished impossibly curved 1/4 panel. |
Scorpio
Posted: Sat Jul 31, 2010 8:16 am Post subject: |
| Gracie wrote: | | I have to say that if you will be painting more than just your car, you'll want to invest in Devilbiss or Sata. Thats all we use at our shop and I have never had a problem. I know that they are not cheap but the saying that you get what you pay for is sooooooo true. I'm sure that you know what you're doing, however I recommend a seperate gun for clear coat. Let me know how it turns out. |
agreed on a separate gun for clear coat, but as far as devilbiss or sata go, iwata is up there on the same level. It is the best gun i could possibly get for the price range, It took me weeks of review reading on all brands before settling with the iwata. Ask different painters what their favourite brand of gun is and youll get different answers, general consensus is that you cant really go wrong with any of those three major brands. The extra $400$600 hundred ide spend on a top of the line sata i could use for a decent air compressor. Our biggets problem painting in brisbane is humidity..causes some major blushing, slower thinners is the key. _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Posted: Sat Jul 31, 2010 1:25 pm Post subject: |
So are you doing the spraying ?? _________________ 1979 porsche 924 Na
Scorpio
Posted: Sat Jul 31, 2010 7:28 pm Post subject: |
| Joes924Racer wrote: | | So are you doing the spraying ?? |
sure am, highly doubt any pro painter will spend as much time and care on my care than i will...short of a $6000+ spray job! _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
dreamgts
Posted: Thu Aug 05, 2010 10:24 pm Post subject: |
Buying a good spray gun is not the only thing that matters in order to get a good paint job. You will have to look at the type of paint being applied and ensure that the nozzles, needles etc are adequate and fit for the material.
One also has to take care of air pressure coming out from the compressor, too much or too little air will ruin the paint job.
You will also have to take note if metallics or any other type of metalic based paints are to be applied. Be sure to continue the coat applied since any intervals here might make the colour look brighter or darker if using metallic paints. Also if metallic paints are used try not to put on over spray onto the next panel since a harsh unpleasnat result might be visible.
I would advise that if metallics are used the paint be constantly stirred so that any metalic flakes will not settle down in the paint conatiner, I would also if your budget affors it purchase a fan type stirer which is attached to the inside of your gun and keeps the paint in motion , also so that no flake settles in the paint container , especially if you are using a gravity gun.
When applying the 2 k laquer , too close a gun will result in the laquer having a whitish effect, too away from the panel will result in unpleasant harshness finish, therefore test paint before you apply. Air pressure is very important here too.
Take all precautions as to filters to the gun, filter the paint well, believe me you will be surprised what comes out with the paint sometimes. also inspect your air compressor for water in the system, a water filter will do the job here. This might sound funny but be sure that your compressor can withhold enough air for you to carry on with 1 full coat without exhausting itself to re-fill with air, this might cause a loss of pressurre at the gun and cause undesireable finished paint.
But before all this one has to take great care that the prep work is satisfactory, believe me you wont regret spending some extra time preparing the car for the paintwork if you want a good pro job finish.
dreamgts _________________ 2 PORSCHE 924 (CURRENT PROJECTS)
2 CLASSIC CORTINAS (FINISHED)
1 CLASSIC FIAT(FINISHED)
1 CLASSIC FIAT 132 2000CC(JUST PURCHASED)
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO
ic932
Posted: Fri Aug 06, 2010 3:09 am Post subject: |
Just shoot it and be happy with DIY results. Even rattle cans with enough thin coats can be cut back and polished to satisty the average DIY bod.
Good luck, I'm sure it will come out great! |
dreamgts
Posted: Fri Aug 06, 2010 7:53 am Post subject: |
| ic932 wrote: | Just shoot it and be happy with DIY results. Even rattle cans with enough thin coats can be cut back and polished to satisty the average DIY bod.
Yes Im sure that will get scorpio that hair raising result he is looking for... very good advice.
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Scorpio
Posted: Mon Aug 09, 2010 5:19 pm Post subject: |
Just sprayed my suzuki sierra for practice with the new gun..results
WOW VERY VERY HAPPY!
the prepaint bodywork certainly wasnt up to professional standard but it was just a quick job before selling her.
Lots of bumps and dents and uneven body filler but the gun laid down the paint beautifully!
NOT 1 single RUN !...paint was a semi satin jet black.. _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
dreamgts
Posted: Mon Aug 09, 2010 8:33 pm Post subject: |
| Scorpio wrote: | Just sprayed my suzuki sierra for practice with the new gun..results
NOT 1 single RUN !...paint was a semi satin jet black.. |
Happy to hear that scorpio, now you need to practice on filling those dents and warps properly with body filler etc. You need to give this attention if you want a good job. Just some friendly advice.
4 SUV'S
2 SEDANS
1 OPEL PANEL VAN
WIFES SUZUKI ALTO |
Scorpio
Posted: Tue Aug 10, 2010 8:29 am Post subject: |
| dreamgts wrote: | | Scorpio wrote: | Just sprayed my suzuki sierra for practice with the new gun..results
dreamgts |
Thanks...i dont need the practice though...porscha doesnt have dents like my 30 year old bush bashing suzuki  _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Scorpio
Posted: Wed Aug 11, 2010 2:29 pm Post subject: |
Good practice.. 924 will have alot more detail and closer inspection to body work along with a clear coat....that satin jet black is single stage _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
