Pre-Racing Engine work
lonestarrpm
PostPosted: Tue Jul 20, 2010 7:13 am    Post subject: Pre-Racing Engine work Reply with quote
Plan to run LeMons than go Spec 944.
but we wanted to look at what we should do to most likely maximize our
longevity of the engine.
we've got a 88 924S.
Plan to do bearings, ARP bearing bolts/nuts.
replace the oil sump pick up, and add a skirt.
is a Dayco timing belt sufficient -- or are folks ponying up the extra $100
for a racing timing belt?
any other must do that are budget reasonable?
thx,
Mike
Porsche M96 Engine Rebuilds
PostPosted: Tue Jul 20, 2010 7:18 am    Post subject: Reply with quote
Buy a new radiator, and don't run a thermostat.
PostPosted: Tue Jul 20, 2010 11:45 pm    Post subject: Reply with quote
I would expect to run the dayco belt.
If you're in there, you might consider lightening/balancing; can be done easy/cheap at home, doing just the rods and pistons...
By skirt, did you mean a crank scraper?
lonestarrpm
PostPosted: Wed Jul 21, 2010 1:05 am    Post subject: Reply with quote
Not that familiar with the crank scrapers,
what i was thinking of was a baffles system.
Mike
PostPosted: Wed Jul 21, 2010 1:41 am    Post subject: Reply with quote
Mike
Mike
There are three options for crank scrapers from Ishihara-Johnson:
A single scraper;
A dual scraper;
Dual scraper with windage tray.
I am a reseller for I-J, so if you're interested in this approach, I can help you acquire the bits you need for less than what you can purchase them directly. Send me a PM if interested.
