I cant get the tank vent to work on the track, how fix?
PostPosted: Thu Jul 15, 2010 6:37 am    Post subject: I cant get the tank vent to work on the track, how fix? Reply with quote
Hi guys.
I have a serious problem, my car (the 931) pisses out fuel out of the vent line on the right in left corners. The tank has been down this winter, cleaned, painted and changed all hoses etc. Didnt do any difference. This only happens when I got lots of fuel in the tank. Its obvious that the small vent line cant vent the pressure out without pushing the fuel out.
What should i do, mount a tiny catch tank ? Why doesnt it work, is it maybe the little plastic valve. It seemed to work ok when I had it out..
My friend with a 924 ´76 has the same problem..
Rich H
PostPosted: Thu Jul 15, 2010 7:04 am    Post subject: Reply with quote
I'd use a catch tank to be certain then a vent line from that.
PostPosted: Thu Jul 15, 2010 8:34 am    Post subject: Reply with quote
Isnt there supposed to be a plastic tank up in the C pillar?
might want to check your hoses and tank routing.
PostPosted: Thu Jul 15, 2010 6:11 pm    Post subject: Reply with quote
No theres no plastic tank on the early models, ive looked in a later 924 (83) and it hade the uppdated setup, with the more squary box on the c pillar, seems like porsche also was aware of this ...My hope are that a small catch tank could separate the gases and fuel. What I dont hope for is for the catch tank to be filled up and the same problem continues.
My first thougths was to have 3 connections, one from the small vent line, one in the top that goes out into the air via the rest of the vent line and the third a return line connected to the thicker tube at the filling. But I dont think that will work since fuel is all the way up to the filler cap in the corners and thus fill fill upp the catch tank instead, maybe if a small valve is put in between so fuel only can go one way. Probably impossible to understand without pictures And the us cars shurely have totally different solutions, but I start to get really worried since more track days are coming in august..
PostPosted: Thu Jul 15, 2010 6:33 pm    Post subject: Reply with quote
mount a one way valve...?
Rich H
PostPosted: Thu Jul 15, 2010 6:47 pm    Post subject: Reply with quote
Or fir a 'roll over' valve, that will pass air but not fuel.
PostPosted: Fri Jul 16, 2010 2:18 am    Post subject: Reply with quote
That will be a bit of a problem, since pressure wants to get out of the tank, as do the fuel..
Isnt a roll over valve already in the system? A white plastic thing with a metal ball inside. Maybe its stuck or something but seemed to work when I had it out. How does a valve that only lets air through work?
Rich H
PostPosted: Fri Jul 16, 2010 2:28 am    Post subject: Reply with quote
It has a float in it that blocks the valve.
PostPosted: Fri Jul 16, 2010 3:09 am    Post subject: Reply with quote
aha, thats why the valve was full of fuel and blocked after a session on the track. When I stopped and opened the cap the pressure got out and the fuel went back in the tank. However it obviosly doesnt get it blocked enough since fuel can pass through in large ammounts. Maybe I could find a new one somewhere. I will search around a bit and see if I find anything.
PostPosted: Wed Aug 11, 2010 2:40 am    Post subject: Reply with quote
Just so this problem gets a solution:
I bought the following valve slightly in panic since I had a track day coming up:
http://www.merlinmotorsport.co.uk/p3555/ROLL-OVER-VALVE-1/4-IN-LINE/product_info.html
Its a valve with both steel ball and floating ball, so I removed the oem roll over valve and installed this. No more fuel passing out the vents and also with no pressure in the tank. Sucess !
PostPosted: Wed Aug 11, 2010 9:56 pm    Post subject: Reply with quote
Thanks for the info.
My tank vent used to be blocked; we'd always have excess pressure in the tank after a race session.
We just pulled the tank after the last race, to fix a crack, and I cut the vent line free from the stock plumbing to allow it to vent successfully.
But I guess we won't have this dumping problem, since we never run a full tank... Well, unless we ever run an enduro!
PostPosted: Thu Aug 12, 2010 2:05 am    Post subject: Reply with quote
And I must always start the day with full tank, or else I have to fill up between the sessions:). 30 l / 100km is a bit problematic consumption wise
PostPosted: Thu Aug 12, 2010 9:39 pm    Post subject: Reply with quote
I think you'll find that if do put the fuel back in after each session, the car will be much more consistent!
These cars are very sensitive to fuel load, as the tank is directly over the rear axle. When you try to balance the car for handling, burning off even as little as 1.5 gal will make a noticeable difference in the balance. That's all of 15 minutes racing for us.
So, to counter this, we always start out with exactly the same fuel level.
As the car burns off gas, it oversteers more and more.
You really ought to do the same.
PostPosted: Sun Aug 15, 2010 6:36 am    Post subject: Reply with quote
The problem can be the use of a Volkswagen Golf(Rabbit) 1 fuel cap.
The VW has no vent holes! The original Porsche cap has some.
Easy fix if you know.
PostPosted: Sun Aug 15, 2010 10:34 am    Post subject: Reply with quote
I wouldnt want to vent at that place. The fuel is right up to the cap in the corners, i havent seen any venting in the cap, maybe i havent looked close enough. But if it exist it doesnt work
