adhesive question
B
PostPosted: Tue Jul 13, 2010 12:53 pm    Post subject: adhesive question Reply with quote
Hey everyone
I wanted to know if anyone knows what type of adhesive was used where the fender is screwed onto the body along the top edge ? - it is gray in color and did not seem like the same seam sealer used elsewhere -(epoxy maybe?)
I am in the process of repairing some rust and wanted to clean things up before coating it up with a rust sealer from Eastwood
funny how you start to work on a suspension and end up repairing the entire front end - fenders and all
any help would be greatly appreciated
thanks
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
BigJohn
PostPosted: Tue Jul 13, 2010 4:51 pm    Post subject: Reply with quote
Funny you should mention starting work on the mechanicals and wandering off to do body and rust prevention, whilst poking round under mine yesterday I was shocked on how much "Loose" under-seal and rust there was on a car supposedly Galvanised? I ended up covered in dust and lumps of underseal, so it was out with the Waxoyl gun and liberal coats of waxoyl sprayed everywhere, but for some reason the mask I was wearing leaked and I ended with a waxed nose, not pleasant. Then noticed the time, rushed inside to get my clothes into the washer before the Wife arrived from work, didn't work as she was suspicious why all of a sudden I was using the washer oops.
Back to your "Epoxy" I should imagine that is exactly what it is. And I wish you well, horrible sticky stuff.
A Furry Creature Told Me I Was Simples
Scorpio
PostPosted: Tue Jul 13, 2010 7:01 pm    Post subject: Reply with quote
not sure just fitted my front fenders..may just leve it out not sure...other option includes seam sealer or rubberized underbody, carefully painted on..black same colour as the engine bay
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
B
PostPosted: Tue Jul 13, 2010 9:05 pm    Post subject: Reply with quote
thanks
yeah I knew there was probably some corrosion that I would deal with come winter, but I saw what looked like a bulge in the lower fender and tapped it with a rubber mallet - - when I heard that crunchy cereal sound I knew I was in a little trouble.
I too have been covered in that white goop that they covered the inner wheel well area with only to be continually disappointed with numerous starts of rust.
So far I am planning to patch any holes, coat with rust encapsulator and chassis black from Eastwood. I have already sprayed inside inner fender with a inner fame coating that is supposed to seal and protect - hopefully that helps as well.
thanks
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
Scorpio
PostPosted: Tue Jul 13, 2010 9:24 pm    Post subject: Reply with quote
ive used POR15 so far still perfect...but thats a year in the garage not in the elements..then again my beast will spend most days in the garage except when it comes out to play
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
my Porsches Arse!!!
PostPosted: Tue Jul 13, 2010 10:44 pm    Post subject: Reply with quote
On the fender - I'm sure that's seam sealer, and not an epoxy that's used between the fender and body (upper engine compartment seam). It's available in different forms, but caulk gun style is best for re-doing that seam.
PostPosted: Wed Jul 14, 2010 3:46 am    Post subject: Reply with quote
You know what Im usin there instead of the epoxy or seam sealer..
is vulkham 116 polyurathane sealant its grey and course ...good stuff
lasts forever. You can get it in smaller tubes at hardwares stores.
B
thanks - that is what I initially thought as well - it just looked much different - I did get some of the sealer in the tube like that -
thanks
Sean
1979 924 n/a
BAE turbo
5-speed snailshell
