juno
Joined: 28 Apr 2004 Posts: 200 Location: Up North, United Kingdom
Posted: Tue Jul 06, 2010 8:49 pm Post subject: Water sloshing around somewhere |
Hi,
I've got water collecting somewhere, and can hear it sloshing around from the drivers seat when I brake and pull away hard.
I've checked the battery area and those drains into the engine bay are clear and the area is dry.
The inside of the car is dry, already replaced hatch seal, roof seals and fiberglassed the battery compartment.
Any ideas where else I might check? _________________ 1980 924 Turbo RHD. 3" > 2.5" Stainless straight-through exhaust. |
Posted: Tue Jul 06, 2010 9:27 pm Post subject: |
Tail light lenses. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Tue Jul 06, 2010 10:20 pm Post subject: |
Inside the door? _________________ Porsche 924 1984 (UK import) NA
Posted: Tue Jul 06, 2010 10:26 pm Post subject: |
Someone here (not myself) once mentioned finding water that could be heard sloshing in the channels at the sides between the battery and fender (wing). (Mine had water too at some time, but drained themselves through rust holes - thus no sloshing.. There are plastic/rubber plugs in the sides of the channels that allow access.. _________________ "..it's made in Germany. You know the Germans always make good stuff."
931Owner
Joined: 14 Feb 2009 Posts: 352 Location: Chicago NW Suburbs
Posted: Wed Jul 07, 2010 12:19 am Post subject: |
Check all your drain holes.
For the doors they may look fine but shove a piece of wire up in each of them to make sure they're draining.
For the sunroof drains... get some garden power trimmer cutter wire or heavy duty fishing line (trimer wire worked best) and snake them through the holes.
In the back... remove the trunk carpet and look down both fender wells for pooling water then drain accordingly. _________________ 1980 Turbo
-too many cars and too many motobikes |
juno
Posted: Wed Jul 07, 2010 6:17 am Post subject: |
Yep Smoothie, you got it on the head. Left hand side full of water, pumped most of it out with a beer making pump.
Any idea how it could be getting in there, and is there a drain for them? _________________ 1980 924 Turbo RHD. 3" > 2.5" Stainless straight-through exhaust. |
