How much is the 928s2 going for?
owenexile
PostPosted: Fri Jun 25, 2010 4:19 am    Post subject: How much is the 928s2 going for? Reply with quote
I drove past one today , made a u-turn and follow the guy ( mind you its the first 92*/944 ive seen down here). Guy turned out to be selling it , he wants Au $7500 for it. Engine still sounds good , Still got the orgininal rims on it , Body got no rust. However the Interior is shot (there was a small burn in the car) Still got dash with few cracks / Original Stereo / Steering Wheel. Only the roof "mat" / Floor Mats , Few Knobs and a door "trim" Need replacing.
Whats the Selling price if u had a 928s2 with these problems?
Thanks
Rudi
924 1982 N/A
For some reason theres always a earth problem somewhere with this car...
Jakkq
PostPosted: Fri Jun 25, 2010 7:48 am    Post subject: Reply with quote
You may get a better response at these boards:
http://forums.rennlist.com/rennforums/928-forum-69/
http://forums.pelicanparts.com/porsche-928-technical-forum/
I do not know much about the S2s'. The 82' 928S Competition Package I own, I bought from the guy for only $3400 with a book of $9,000. Just needs some paint and Ignition switch fumbling, but I am also restoring the interior for a better look.
They are great cars, but they don't usually run cheap.
1979 Porsche 924- Snailshell
http://porsche924workblog.blogspot.com/
owenexile
PostPosted: Fri Jun 25, 2010 11:49 pm    Post subject: Reply with quote
Thanks for that.
Been thinking today , y buy the 928 with its own problems if im gno do a v8 swap on my 924 someday. Im also looking for something more "trust worthy". Might regret it someday but im giving this one a miss
Thanks
924 1982 N/A
bnoon
PostPosted: Sat Jun 26, 2010 12:53 am    Post subject: Reply with quote
I've been liking the 928's too. If one comes for the right price, I'll be doing an LS1 based swap into one of those if I don't go with a V8 swap into the 931 that is. If I do a 931 V8 swap, then I'll most likely go with a 928 S4 and keep it stock. My mind changes daily though.
'80 924 Turbo - SOLD!
1986 Porsche 944 Turbo - SOLD!
Porscheless
sbarc
PostPosted: Sun Jun 27, 2010 9:10 am    Post subject: Reply with quote
The only real issue with the 928 is the dismal gas mileage......my 1990 928 GT gets about 12mpg (that's an imperial gallon). But it does weigh over 3200lbs and it does have 330 HP....so that might help partially explain the gas mileage. Buying one is not the issue........living with the running costs is the real trick. But they are a solid car with few issues if taken care of. There really is nothing like them and they are vastly different from the 924/931......not better or worse....just different. I enjoy the highway on ramps in my 928 when I can spend a few seconds getting up to speed before slowing down to the speed limit to merge into traffic. It's hard to get caught speeding in the 928......you can get a very quick thrill from the acceleration before returning to normal speed.........in less powerful cars you spend much more time driving fast trying to get the same thrill. There is something to be said for brute power. And as for the styling......the 928 is just simply beautiful and unique in my eyes.
1981 931 (Canadian car)
1981 931 (US car)
1990 928GT (ROW car)
1991 Toyota MR2
1989 Toyota MR2 Super Charged
1985 Toyota Supra
1973 Triumph GT6
1971 Opel GT
356speedster
PostPosted: Mon Jun 28, 2010 9:34 am    Post subject: Reply with quote
Yes, the 928 is a different animal, a very nice one though
Gas mileage depends on the use, when used for small trips it can be pretty thirsty but for longer trips is actually not that bad. It's usually the urge to floor it to feel the power that increase the gas bill
I commuted all seasons with my S4 for a couple years covering 130 km (80 miles) per day on a combo of B-roads, highway and city jams. The all time average was at tad over 12 liters pr 100 km (20 US mpg, or about 16 imperial mpg)
In the winter you quickly learn to steer it with the pedal, but it's very nicely balanced so you can have fun all day long
I would be careful buying one that have had "small fire" as the OP mentioned. The main issues with the 928's are electrical (bad grounds), vacuum and sensor related, so I would stay away from a car that might have had an electrical fire.
bnoon: A LS1 in the 928 is blasphemy! if you need more power than the 320/330/350 HP in the later models (S4/GT/GTS) you go forced induction. The engine is rock solid and there are several bolt-on supercharger kits available in different stages almost up to 600 HP using the stock fuel system with only a few minor mods (bigger injectors and data mapping of the stock injection/ignition brains). There is also a twin-turbo kit in the making that's dyno'ed to over 500 wheel hp.
1982 Porsche 924 na My 924 blog
1990 Porsche 928 S4 My 928 blog
1995 Fiat barchetta
2007 BMW 318d M-Sport
2010 Volvo V50
PostPosted: Wed Jun 30, 2010 2:41 am    Post subject: Reply with quote
To the OP,
$7500 AUS seems reasonable. People forget that the market over there has a much higher demand, and therefor gets higher prices.
Sbarc,
if your GT is only getting 12MPG something is WRONG!
In the city I average 17-19MPG depending on how hard I push.
On the freeway I can get 22-24MPG doing the limit.
And when pushing the car with average speeds of around 172kmph, and speeds up to 240kmph I average 17MPG. (on the track of course )
You should consider coming over to the mainland. I am in Abbotsford now, and having me give the car a look over as that is what I do for work now.
I also have the sharktuner, and can tune your car for much better mileage. But from the sounds of it, I would be willing to bet that your car needs an O2 sensor, as well as a top end refresh. But it could also have a fuel dampner or 2 that is cooked.
3 928s,
PostPosted: Wed Jun 30, 2010 4:11 am    Post subject: Reply with quote
Lizard wrote:
To the OP,
Yeah, often people on the 'board forget (or disregard) that. With vehicles, you can often double (or even triple ) a U.S. price and still be in the ballpark in Oz (oddly, this seems to be similar in Germany and various other European countries, not to mention Asian countries, too). Although I'd argue that in Oz, demand is not the only reason (probably not even the main reason) that vehicle prices are much higher. The currency is worth less (worthless? ), for a start. Vehicles are generally much more expensive to purchase new (currency rates, taxes and other reasons), which means with the same or similar percentage depreciation, the resale price remains higher. And, although the Yanks might think I'm having a dig at them, which I'm not (at least, not this time ), luxury vehicles such as Porsches seem to be kept in better condition, generally speaking, than you tend to find in the U.S. This is possibly as much to do with climate as with anything else. But I suspect the relative scarcity of these types of cars in Oz just prompts people to look after them a little better, as well.
Anyway, many reasons, but the end result is that cars in Oz are just much more expensive.
bnoon
PostPosted: Wed Jun 30, 2010 7:47 am    Post subject: Reply with quote
To you perhaps, but with broken down LS1's, or better yet broken 6.0L LS2's, or better yet 6.2 LS based truck engines for sale in every junkyard across the entire USA vs the same price for a 20-30 year old Porsche engine that I can find maybe a handful of nation wide in much worse condition... I think the choice is clear. Not to mention an LS based engine can be over 500 HP at the wheels with a cam, head swap, and headers in NA. Then add turbos to that. In fact, I think you help me make up my mind to go cut one up... Now where's that blow torch?
Porscheless
the_mad_electrician
PostPosted: Thu Jul 01, 2010 9:56 am    Post subject: Reply with quote
I think I'm with you bnoon. I was doing research on 928s looking at the outragous cost of parts for the car kind of changed my mind about a possible furture purchase of one. The only cams i found online were over $2500! Almost every example of 928 I have found within 500 miles of my location has had at least 100K miles so a rebuild would be in order sometime or another. I've heard the argueement that the engine is rock solid but if I have a car like that I'm going to drive it hard as it can go and a 160K mile engine solid or not does not like the way I would drive it! Well I didn't mean to rant. LoL
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
