ANYONE DOING ANYTHING EXCITING ON THEIR CAR ?
Goto page Previous  1, 2, 3 ... 21, 22, 23 ... 150, 151, 152  Next
daniel
PostPosted: Tue Jun 22, 2010 4:28 pm    Post subject: Reply with quote
Bleeders always up, they are supposed to be the highest point of the caliper otherwise you can trap air in the caliper. Also, what rotors are they? 944 ones or others?
1989 944 Cabriolet
PostPosted: Tue Jun 22, 2010 10:54 pm    Post subject: Reply with quote
Joes924Racer wrote:
Are the bleeders on the calipers supposed to be pointing up or down.
I think Ive mounted them on the wrong sides. Clarify. Can someone
point me in the right direction.
Bleeders up on mine
ZODIAC
PostPosted: Tue Jun 22, 2010 11:24 pm    Post subject: Reply with quote
trying to sell it
"Kraut cars, they know how to build 'em".
1977 924 N/A - Red with waterdamage interior
yes...waterdamage is now a color...
Mike9311
PostPosted: Wed Jun 23, 2010 3:40 am    Post subject: Reply with quote
CorsePerVita wrote:
Damnit dan. Those look more tempting now.
Heheh! Here's a set we just had made up for another forum member. 8.5:1 Euro spec 931 pistons:
Dan, did you weigh these? They really look nice and light
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
PostPosted: Wed Jun 23, 2010 4:44 am    Post subject: Reply with quote
[url.=http://picasaweb.google.com/lh/photo/AFQdKrZKkJ_Tg-tUjvOheg?feat=embedwebsite][/url] [url.=http://picasaweb.google.com/lh/photo/OEnqmGiIoeBXzgOpXtjiug?feat=embedwebsite][/url]
[url.=http://picasaweb.google.com/lh/photo/soUI9OCWviry-2aWrjUcgg?feat=embedwebsite][/url] [url.=http://picasaweb.google.com/lh/photo/lfGCY2XAyXG6XmJJkoTyJw?feat=embedwebsite][/url]
[url.=http://picasaweb.google.com/lh/photo/uQK19Rk9OIhbuPRKCrjO2w?feat=embedwebsite][/url]
Looks sweet, the weight would be really interesting. Do they have the measurments in house now for the s2 pistons? I have some future plans
PostPosted: Wed Jun 23, 2010 4:47 am    Post subject: Reply with quote
Yea plenty Sweet.. how long does the coating last i wonder,
Wonder if that dude that also has 924 furniture has drooled
over them yet.
PostPosted: Wed Jun 23, 2010 4:50 am    Post subject: Reply with quote
Cost = $650, including wrist pins, double spirolox retainers, total seal rings, and coatings. Considering the cost of OEM rings alone, as well as the cost of JE pistons and other alternatives, I think these are quite a good deal.
+10, assuming the quality is comparable to other custom blends, this is a monster deal.
PostPosted: Wed Jun 23, 2010 5:01 am    Post subject: Reply with quote
yea La Monsta
Mike9311
PostPosted: Wed Jun 23, 2010 5:43 am    Post subject: Reply with quote
I must admit I didn't catch that part about "Total Seal" rings the first time around. I know Total Seal made 924 rings back in the day because I bought a set for the 80NA. Last I checked it seemed they would have to be custom but I only looked in their catalog recently.
That really is a good deal with all that.
1980 931 since 1989
PostPosted: Wed Jun 23, 2010 7:35 am    Post subject: Reply with quote
I had a set of total seal too i believe anyway I have ome free time
a few hrs at the least
.. I should torque the front down install
the rack bleed the brakes. Then later see bout getting the wheels
on.
Still need to figure out the cooling fan times ill just switch wire it
so i can move it around and well run it
Getting time for the body
work phase. Thats alot with work on the turbo too as it should remain a roller I think.
flosho
PostPosted: Wed Jun 23, 2010 12:41 pm    Post subject: Reply with quote
Got my car aligned today for the autocross this weekend. -2.6 degrees of camber in the front and a slight toe out. Can already feel a difference.
[This Space For Rent]
PostPosted: Wed Jun 23, 2010 2:51 pm    Post subject: Reply with quote
Put on the pads and bleed the system after torqueing all the mounting points.
PostPosted: Wed Jun 23, 2010 6:04 pm    Post subject: Reply with quote
Why did you not fit braided stainless steel brake hoses? Did you spend the extra cash on a pedicure instead??
Nein37
PostPosted: Wed Jun 23, 2010 10:26 pm    Post subject: Reply with quote
Nice work Joe!
1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears.
Mike9311
PostPosted: Thu Jun 24, 2010 1:47 am    Post subject: Reply with quote
Trying to do some maintenance on the '82 931. Cleaned up, painted, turned, and rebuilt the front brakes. Also replaced the drivers side strut mount, and tie rod ends. Some of this stuff was never touched on this car.
Then this fell out from behind the dash which explains a few things. Was thinking this should go under laugh of the day....
A wee bit of harness work up next followed by a new timing belt and likely a cam/follower swap out.
Tires came too. Trying out some Eagle GT's for the stock rims. Needed something quick and reasonable. A bit heavy for my taste but I keep forgetting they are 15" kims which means more tire carcass. They do have a rim protector which surprised me.
1980 931 since 1989
Page 22 of 152
