How To Upgrade your Toofah to Four Pot Brembos
PostPosted: Wed May 19, 2010 3:53 pm    Post subject: How To Upgrade your Toofah to Four Pot Brembos Reply with quote
This is a three step process.
1) Acquire Four Brembos (86 951 is ideal candidate)
2) Acquire 86 951 Steering Knuckles, Strut Assemblies:
3) INSTALL!
Wow, they look a lot better bolted up, don't they?
Also, don't forget you need to have the driver's side spindle drilled for your speedo cable (my machinist said not to worry about potential for "weakening" the part), and have the cap milled with a 5mm square to accept the drive end of the cable.
Number-sign-in sexy, you ax me.
Rich H
PostPosted: Wed May 19, 2010 5:16 pm    Post subject: Reply with quote
Why don't my parts suddenly clean and paint themselves
thirdgenbird
PostPosted: Wed May 19, 2010 9:39 pm    Post subject: Reply with quote
how did you put the bias valve in?
i have an oem 951 bias valve but it doesnt look like it will fit without a 951 brake line.
17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel
PostPosted: Wed May 19, 2010 11:45 pm    Post subject: Reply with quote
It's been reported that no proportioning valve is needed with the "big" master cyl on 80 and later cars. . .I haven't driven it yet, so I guess I'll find out. With early toofah line routing ("X" split), installation of a proportioning valve would be a challenge. . .you'd need one valve for each rear wheel.
PostPosted: Wed May 19, 2010 11:51 pm    Post subject: Reply with quote
You didn't change to a front-rear split?
PostPosted: Thu May 20, 2010 12:06 am    Post subject: Reply with quote
I didn't. . .we'll see what happens!
thirdgenbird
PostPosted: Fri May 21, 2010 10:32 am    Post subject: Reply with quote
ive got a 924s. i take it we have a different line setup...
PostPosted: Fri May 21, 2010 12:15 pm    Post subject: Reply with quote
I dont get 4 pot brembos...
9XX Girl!
PostPosted: Fri May 21, 2010 2:29 pm    Post subject: Reply with quote
I don't get... the change of avatar and the paint strip-down either, but each to their own hay.
PostPosted: Sat May 22, 2010 11:05 pm    Post subject: Reply with quote
Is that M030 dampers as well or sleeved and repainted stock 951?
I had a set of 951 M030, Brembos, axles etc. and sold them before fitting!!
PostPosted: Tue May 25, 2010 11:44 pm    Post subject: Reply with quote
They are regular late strut assemblies, painted and with a coilover kit installed.
Thirdgenbird, your S does have a different line setup (TT, or "front/rear split"), as well as equal sized calipers front to rear and a stepped master cylinder.
