gla924sem
Joined: 08 Nov 2002 Posts: 405 Location: Taylor, Michigan
Posted: Fri May 21, 2010 6:57 pm Post subject: Switch speedometer and tach location |
Would rather see the tach in the center of the instrument cluster than the speedometer.
Makes more sense as I race/track the car
Anyone do this??? Any issues in doing???
First look......seems like its possible |
Posted: Fri May 21, 2010 8:27 pm Post subject: |
Gary, absolutely doable. The biggest issue in doing it is to make sure you have sufficient slack in the speedometer cable. It might require you to re-route it in the engine bay, and then push it further into the cockpit, but it is definitely doable. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat May 22, 2010 12:44 am Post subject: |
Done this, the key was to unhook the bunch of electrical cables that were in the way and just put them som cm away. The biggest problem here is the angle on the cable (speedo), the wire needs to be curved very carefully or you will have problems with a not so smooth speedo afterwards. The hardest thing is that there is some metal in the way for the cable, but the cable can be moved so it will be acceptable.
 _________________ 1980 924 Turbo
Posted: Sat May 22, 2010 3:56 am Post subject: |
mmmmm, early turbo green gauges, nice.
Mine is the same, only diffy is that I turned the tacho about 90 degrees CW so redline is straight up. That way I don't actually have to look to know I'm at (or over ) redline. |
Posted: Sat May 22, 2010 10:35 pm Post subject: |
Moved mine around a couple of weekends ago. Also re covered the gearshift with black suede leather to match the Momo wheel.
 _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
smart931
Joined: 09 Apr 2010 Posts: 116 Location: Carmel Valley, California.
Posted: Sun May 23, 2010 3:19 am Post subject: |
My car was like this when i bought it. I switched it back.
I really like the choice of steering wheels in those pics. _________________ 1982 Porsche 931 (Sold)
2000 Smart Fortwo (Waiting for import)
1972 Opel manta (Left in England)
1965 Chevrolet Corvair (Left in England)
2010 Mazda 3 (Ex got this in divorce)
1974 Triumph TR6 (sadly gone)
1968 Ford F250 Camper Special (Daily) |
Posted: Sun May 23, 2010 4:26 am Post subject: |
Mr. RSR, what boost gauge is that? Looks really nice with the 931 green gauges... _________________ erstwhile owner of just about every 924 variant ever made |
thirdgenbird
Joined: 29 Feb 2008 Posts: 367 Location: Pella, IA USA
Posted: Sun May 23, 2010 2:16 pm Post subject: |
i did both of these mods too.
steering wheel:
tach mod:
 _________________ 17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel |
Posted: Sun May 23, 2010 8:22 pm Post subject: |
| ideola wrote: | | Mr. RSR, what boost gauge is that? Looks really nice with the 931 green gauges... |
Its a boost gauge by TIM. Just needed some additional green marker pen on the white numbers and some orange paint on the needle. Ideally would like a custom vdo 1.5 bar gauge done to match in perfectly. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
