Bognostraclum
Posted: Wed May 12, 2010 4:45 am Post subject: Injectors |
Are the injectors on a standard S2 electronic or mechanical?
I'm thinking about going standalone. I'm suspecting the standard ones can't be used?
I've read something about injectors from a type of Mondeo? I'm no expert on the matter, so any extra help is appreciated.
Cheers |
Posted: Wed May 12, 2010 5:03 am Post subject: |
Open yer hood, if ya got one, and look~! No injector electrical connection on the stock turbo cars.  _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Bognostraclum
Posted: Wed May 12, 2010 8:25 am Post subject: |
| Grenadiers wrote: | Open yer hood, if ya got one, and look~! No injector electrical connection on the stock turbo cars.  |
My car stands in a garage @ 20k for now. (Phew, an excuse to cover up the fact that i am indeed a Noob! Seriously, i wouldn't have thought about actually looking @ the damn things if the car was standing here )
Ok, second question: Can i simply screw other injectors in the original locations or do i have to modify the manifold? Which injectors would be a good choice? |
Posted: Wed May 12, 2010 8:57 am Post subject: |
Rather than rehash things, do a quick search on this board for MegaSquirt. Specifically there was at least one post in the How-To section.
However, here's a summary:
You need to machine your stock injector inserts to hold the O-rings for your injectors (I'm machining my head, to eliminate the inserts, but then I'm a little weird)
Find or build a fuel rail to fit the injector spacing in the cylinder head, fit the injectors you're using and fit under the throttle body. This will take some effort to do.
Fuel lines will need to be adapted.
Ignition will need to be adapted for use with the EFI system you choose (or another system adapted to work in place of the stock solution)
Throttle body needs a throttle position sensor added.
Air intake needs to be changed to eliminate the CIS system.
Sensors installed in the engine bay and properly wired
Electrical system modified to for the EFI system
You'll need to tune the fuel and ignition systems, which is a lengthy process, made quicker by use of a Wideband Oxygen sensor and eventually a dyno-tuning session or two. _________________ Stefan
Bognostraclum
Posted: Wed May 12, 2010 11:20 am Post subject: |
| Thanks for the info! |
jessy1984
Posted: Sun May 16, 2010 1:25 pm Post subject: |
| Bognostraclum wrote: | | Thanks for the info! |
i see you 'r from belgium to
you can also find ino on 924forum nl
iff you want to change the injection to an EFI this can be done by using the complete injection of a mondeo 1.8 but keep in mind its a lot of work iff you dont know much about this dot start with this |
Nein37
Joined: 29 Dec 2009 Posts: 513 Location: New London, CT
Posted: Sun May 16, 2010 8:13 pm Post subject: |
Want is your reasoning for changing the injectors? Unless you are going EFI the stock injectors will flow plenty of fuel even for high boost applications. _________________ 1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears. |
Bognostraclum
Posted: Mon May 17, 2010 1:23 am Post subject: |
| jessy1984 wrote: | | Bognostraclum wrote: | | Thanks for the info! |
Thanks for the info. I was already planning on checking that forum .
About those Mondeo injectors, i was wondering if they give enough fuel for a 931 because they were only mentioned in N/A conversions?
I know i don't know that mutch about the subject, but i'm eager to learn. It's actually the reason why i bought the 924 in the first place. |
Bognostraclum
Posted: Mon May 17, 2010 1:27 am Post subject: |
| Nein37 wrote: | | Want is your reasoning for changing the injectors? Unless you are going EFI the stock injectors will flow plenty of fuel even for high boost applications. |
The reason is that i'm planning go EFI  |
jessy1984
Posted: Mon May 17, 2010 1:38 am Post subject: |
| Bognostraclum wrote: | | Nein37 wrote: | | Want is your reasoning for changing the injectors? Unless you are going EFI the stock injectors will flow plenty of fuel even for high boost applications. |
ok here 's a start for you
http://www.924board.org/viewtopic.php?t=21148
and
http://www.924board.org/viewtopic.php?t=26278
i sugest you can put the efi in keep everything of the mondeo
after you installed it dont try to drive the car but bring it to a spesialist tuner
they have all the tools to messure the flow and change it by using diferent injectors and tune the engine computer
never just install something else cous it can cous a lot of damage to your engine /pistons
there is a company in holland that can do these things but i forgot the name meet with these peaple first befoe you start any work |
Bognostraclum
Posted: Mon May 17, 2010 1:44 am Post subject: |
I've been going through some older threads and i think i've found a helpful and experienced crowd in here.
I've owned some 924's already, but i always was a bit scared to mess with a running car.
I've finally decided to give it a try and just see what happens, hoping my wallet will survive somewhat .  |
Bognostraclum
Posted: Mon May 17, 2010 1:46 am Post subject: |
| jessy1984 wrote: | | Bognostraclum wrote: | | Nein37 wrote: | | Want is your reasoning for changing the injectors? Unless you are going EFI the stock injectors will flow plenty of fuel even for high boost applications. |
and
Thanks! Saves me a lot of searching!
Is it really that dangerous to try tuning the engine yourself? As far as i know (i don't know mutch) the two biggest dangers are knock and running lean.
I was thinking it was doable with a lambda/MAF sensor(to control A/F ratio or do i need something else?) and a ping-detection sensor, starting with a rich running engine and conservative timing?
Feel free to correct me on this!  |
Min
Posted: Thu May 20, 2010 1:02 am Post subject: |
Its not dangerous if your careful.
