HELP: OEM SPEC NEEDED: Lifter Adjusting Screws
PostPosted: Fri May 14, 2010 1:53 am    Post subject: HELP: OEM SPEC NEEDED: Lifter Adjusting Screws Reply with quote
ARP has finally responded re: our little lifter adjusting screw project. I have been unsuccessful finding exact specifications on these little buggers. The tech specifications booklet indicates that more notches = thicker screw (which we know), but it doesn't say what the variance is. The other critical dimension that would be really helpful to have is the angle of the flat. I know some of you have actual engineering blueprints of the 924 engine. Any chance somebody has the exact OEM specs for the lifter adjusting screws?????
PostPosted: Fri May 14, 2010 2:14 am    Post subject: Reply with quote
FWIW, the angle should be calculable from the thread pitch and the increase in thickness per turn, which I believe is stated in FSM.
PostPosted: Fri May 14, 2010 2:21 am    Post subject: Reply with quote
It occurred to me there might be some info in FSM, but I don't have it here at work. Do you recall if FSM says anything about the difference in thickness between the different number of notches?
PostPosted: Fri May 14, 2010 2:26 am    Post subject: Reply with quote
its .002 per turn and .005 diff per screw *but they do vary some* even within the same number of notches
I have a bunch of the screws. What do you want me to measure?
PostPosted: Fri May 14, 2010 3:03 am    Post subject: Reply with quote
Need to know the angle of the flat. Anybody know the thread pitch???
It would also be good to verify that the .005 difference between sizes is what you actually see on existing samples. I sent one of each size to ARP, and I've asked them to measure, so it would be good to compare notes. I have some at home too, so I'll see what my calipers say as well.
PostPosted: Fri May 14, 2010 4:28 am    Post subject: Reply with quote
I can get you the pitch tomorrow, if someone hasn't already.
PostPosted: Fri May 14, 2010 4:43 am    Post subject: Reply with quote
Would be much appreciated.
Min
PostPosted: Fri May 14, 2010 5:20 am    Post subject: Reply with quote
Angle of the slop should be easy to figure out, simple rise over run calculation. I'll see if I can dig out an adjuster screw so I can make that measurement for you.
Min
Min
PostPosted: Fri May 14, 2010 5:56 am    Post subject: Reply with quote
I'm doing a autocad drawing right now of the screw I've got.
Min
Min
PostPosted: Fri May 14, 2010 7:14 am    Post subject: Reply with quote
http://www.924board.org/viewtopic.php?p=292203#292203
With a pitch of 0.75 and a slope of 4 degree's, you will have tan 4 degree's times 0.75 = 0.052mm movement for each turn. Which is .00206 of an inch. Sounds right to me.
Min
PostPosted: Fri May 14, 2010 7:16 am    Post subject: Reply with quote
Min, you rock!
Min
PostPosted: Fri May 14, 2010 7:21 am    Post subject: Reply with quote
heh, thank you, I'll see if I can dig out any other screws in a bit, I was only able to find a 3 tick screw. If someone else wants to give their screws a quick measure to verify that I measured correctly that would be cool too.
The diameter measured at 7.8mm, which is the same as the M8 rod I have laying around. Makes sense M8x0.75 is available, just not that common.
Min
PostPosted: Fri May 14, 2010 7:25 am    Post subject: Reply with quote
Did you confirm that the pitch is .75?
Min
PostPosted: Fri May 14, 2010 7:29 am    Post subject: Reply with quote
With my thread pitch gauge. Yes.
Min
Min
PostPosted: Fri May 14, 2010 7:34 am    Post subject: Reply with quote
Also measured it with my vernier micrometers which are accurate to .0001 of a inch.
Min
