Audi 2.5 TDI
Mathias
PostPosted: Mon Mar 17, 2008 5:05 pm    Post subject: Audi 2.5 TDI Reply with quote
http://www.youtube.com/watch?v=0_j-c8piGn4
First testrun
PostPosted: Tue Mar 18, 2008 12:29 am    Post subject: Reply with quote
Wow, there has been a lot of blah blah blah on this topic, you actually did it! Nice job on the oil pan, but it looks like limited slip might be helpful.
I am sure I speak for others when I ask whether you'll be posting more info on this conversion. Great job!
rasta
P.S. What is your plan for the hood?
Mathias
PostPosted: Sat Mar 22, 2008 5:38 am    Post subject: Reply with quote
yes a limited slip would be nice! but there are plans for audi 6speed transmission it revs to much like it is now.
The diesel engine and most audi 5cyl are almost the same so this conversion works for them also.
engine is tilted about 8 degrees for manifold and turbo clearance,the tourque tube flange is just cutted and rewelded.
New made oil pickup
oilfilterholder is rotated forward for clearance and water/oilcooler is changed for external oilcooler (not in picture)
Flywheel is from a volvo 240 diesel(uses 6 cyl audi diesel) and it hade material removed so the 240mm audi pressureplate fits.
Even had to remove material from pressureplate! not much room in porsche bellhousing
engine mounts
Engine is about 100mm longer than 924 engine and antirollbar is lowered.
Never mind the date! my old camera always reset when the batterys are dead
Thats it!
gegge
PostPosted: Wed Apr 02, 2008 5:18 am    Post subject: Reply with quote
Are you registered on www.944sverige.com ?
Carl Fredrik Torkildsen
endwrench
PostPosted: Wed Apr 02, 2008 1:27 pm    Post subject: Reply with quote
Impressive job on the motor mounts and the clutch setup. Looks like a fairly tight squeeze in certain spots. Just wish I had highspeed so I could look at the video!
Todd
PwrGTOGuy
PostPosted: Thu Apr 03, 2008 10:04 am    Post subject: Reply with quote
Awesome work buddy... Now, I also have to thank you for your music choice in the video... I have had the song stuck in my head for 2 days... I go to sleep thinking about it, wake up thinking about it... sing it all day...
mathew
PostPosted: Sat Apr 17, 2010 3:58 am    Post subject: Gear box ratios Reply with quote
To the guy with the 5 cylinder diesel... have you changed your gearbox ratios as top speed would not be much at max rpm?
Any chance of creating a parts list for the conversion as I am tempted to build a 931 diesel
Thanks
Mathew
