midohioweld
Joined: 23 Jan 2010 Posts: 10 Location: Lexington Ohio
Posted: Wed Feb 10, 2010 11:40 am Post subject: 1980 turbo with LT1 started |
Well I am well on myway to installing the LT1.Making all my own parts going pretty well.Motor mounts are in and mocked up,oil pan done,bellhousing done.Radiator and clutch and it will really start to come together.If I can figure out how to post pics I will.[/img] _________________ God gives us all talents it is up to us how we use them!! |
midohioweld
Posted: Wed Feb 10, 2010 12:25 pm Post subject: pics |
Rocco R16V
Posted: Wed Feb 10, 2010 1:32 pm Post subject: |
very cool  _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
Posted: Wed Feb 10, 2010 2:14 pm Post subject: |
Go, baby, go (951 gearbox/suspension requested)! _________________ Toofah King Bad
bnoon
Joined: 12 Oct 2009 Posts: 607 Location: West Des Moines, IA USA
Posted: Thu Feb 11, 2010 10:03 am Post subject: |
How far back did you have to take the oil pan to clear the cross member? Can you measure what's left for me? I have a rear sump pan that was made from two 4.3 V6 pans cut and welded together (from a v8 S-10 swap kit I got YEEEEEEEEEARS ago) and I want to know if it would fit. It almost looks like a front sump pan would clear too.
Which trans adapter setup are you going with?
I'm thinking of adapting an LT1 intake to a gen 2 block (87+ roller block) like I did when I had my 86 Trans Am. Then I can use my TPI harness I already have too. Hummmmmm, I'm getting closer and closer to selling my turbo 4 popper running gear and going for it. _________________ '80 924 Turbo - SOLD!
1986 Porsche 944 Turbo - SOLD!
Porscheless  |
midohioweld
Posted: Thu Feb 11, 2010 11:18 am Post subject: pan specs ect |
I will measure the pan for you tomorrow as for the bellhousing it is custom made using an modified stockcar bellhousing and I am going to use an external slave for the clutch.The adapter for the bellhousing was made in house and welded to the existing bellhousing with the depth set to match for the porsche input shaft.It is really close to the same depth but we had to inset the adapter 3/16 inch.Hope this helps.John :  _________________ God gives us all talents it is up to us how we use them!! |
AppleBit
bnoon
Posted: Mon Apr 12, 2010 8:57 am Post subject: |
Any updates on this??? _________________ '80 924 Turbo - SOLD!
Porscheless  |
v8carreragts
Posted: Tue Apr 13, 2010 12:33 pm Post subject: |
This is my pan.
Here are the dimensions I used
Rich H
Posted: Tue Apr 13, 2010 4:44 pm Post subject: |
I thought you had found yourself a VW LT Van engine for a minute...  _________________ 1994 Lotus Esprit S4 - Work in progress...
bnoon
Posted: Wed Apr 14, 2010 12:51 am Post subject: |
| v8carreragts wrote: | This is my pan.
Here are the dimensions I used |
Thanks for the feedback. Tons of room for the pan I have. Very cool!!! I think I need to go offer my 4 popper for sale now!
Did you also make your own torque tube adapter??? _________________ '80 924 Turbo - SOLD!
Porscheless  |
v8carreragts
Posted: Wed Apr 14, 2010 6:05 am Post subject: |
[quoteDid you also make your own torque tube adapter???[/quote]
Adapter:
Motor Mounts:
Hydroboost:
Jaguar front calipers
