tyre size for 937 replica
Dutch924-racer
PostPosted: Mon Apr 05, 2010 5:39 pm    Post subject: tyre size for 937 replica Reply with quote
What is a good tyre size for a 937 replica (my car is very low and neg camber)
Original:
Front: 205/55/16
Rear: 225/50/16
Would 245/45/16 fit in the rear or even wider 265 ?
My front wheels are 7J ET23
Rear I have 8J ET11
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Mon Apr 05, 2010 6:51 pm    Post subject: Reply with quote
If you want to go fast its as wide as the wallet want. (but you maybe dont drive that one at the track?). It also depends on tyre choise, if you have r-compunds for the track they are much wider than street tyres at the same width. But to those rims andīr compund i wouldnt go with more than 205 at front and 225s at the rear. If you want to go fast and change wheels I would maybe chose something like 255 toyo r888 all around, if you not have heaps of power (280hp+). Many 944 race cars use that sizes because its fast and you can swap the tyres around so you can run them a bit longer..
Dutch924-racer
PostPosted: Tue Apr 06, 2010 3:28 pm    Post subject: Reply with quote
This set is just for road use.
937 trackday car
Series 2 engine
Fast road camshaft
