Turbo Bolts
Goto page 1, 2, 3  Next
PostPosted: Fri Apr 02, 2010 3:49 am    Post subject: Turbo Bolts Reply with quote
Reassembly time is nigh. I am considering ditching the allen head cap nuts that hold the bearing housing to the bracket. . .they are so old, and made from such odd material, how can they not be worn out?
So, I have two questions. First, any reason not to use a locking hex nut? And second, how does one adjust for torque values when switching from a regular to locking nut?
TIA
rasta
PostPosted: Fri Apr 02, 2010 4:06 am    Post subject: Reply with quote
I don't know that there is a difference in torque settings between a locking nut and a non-locking nut.
!tom
PostPosted: Fri Apr 02, 2010 5:13 am    Post subject: Reply with quote
Intuition would tell me that you would measure the torque required to "spin" the nut on, then add this to the published torque value for the fastner.
That is, of course, if you use the same thread as you did previously. The thread pitch largely determines the correct torque for any application, as it's the clamping force that is important. Bolt diameter is important too so that the bolt stretches the correct amount, to ensure the bolt is under continuous tension given the dynamic loads of the part.
78 924 NA
5-lug
PostPosted: Fri Apr 02, 2010 5:47 am    Post subject: Reply with quote
I have regular hex bolts on my car (PO changed them and I continued to use them), works nice and is so much easier to assemble/disassemble than the allen ones.
PostPosted: Fri Apr 02, 2010 6:48 am    Post subject: Reply with quote
Of course there is, for the same reason that some torque specs specify dry or wet threads, and some even change according to type of lubricant (think ARP head studs).
The locking nut resists torque, so is not giving the same amount of bolt stretch as non-locking.
Rich H
PostPosted: Fri Apr 02, 2010 8:28 am    Post subject: Reply with quote
What he said, you need to add the run down torque to the desired torque
ic932
PostPosted: Fri Apr 02, 2010 9:03 am    Post subject: Reply with quote
Been awhile, but these are very low torque bolts no? Unless you feel its benificial to easy instalation (lock nuts) then I would just torque then to spec (whatever that might be) then nip them up a lil' more. I doubt I got a torque wrench that is that low...just feel when its good.
Min
PostPosted: Fri Apr 02, 2010 11:51 am    Post subject: Reply with quote
If your going to be that picky about torque you better simply measure bolt elongation instead. Since such things as bolt coatings effect their friction factor as well as lubrication. Cadmium plating for example produces approximately 33% less friction than untreated steel. Were as lubrication only changes it by 5%. I'd suggest measuring elongation or you could also use load indicating washers to detect when the correct torque has been achieved.
Torque wrenches aren't really that accurate in the first place really. Their relative accuracy is pretty low.
http://www.boltscience.com/pages/tighten.htm for more information.
http://www.turnasure.com/direct-tension-indicators-turnasure-bolting-technology.shtml
for some tension indicating washers.
Min
Min
PostPosted: Fri Apr 02, 2010 11:57 am    Post subject: Reply with quote
could also get yourself some 'squirter' DTI washers (direct tension indicating)
http://appliedbolting.com/squirters.html
They squirt out silicon when they are at the correct tension.
Min
PostPosted: Fri Apr 02, 2010 1:01 pm    Post subject: Reply with quote
The stock ones work and I've reused them before.
PostPosted: Fri Apr 02, 2010 1:14 pm    Post subject: Reply with quote
I'm going to look at Stage8 locking bolts and nuts for the exhaust mani and turbo applications on my upcoming Euro spec engine build...
PostPosted: Fri Apr 02, 2010 1:21 pm    Post subject: Reply with quote
I'd stick with the stock ones, they were specified to withstand the red hot heat.
Min
PostPosted: Fri Apr 02, 2010 1:24 pm    Post subject: Reply with quote
personally if I was interested in locking those fasteners properly, I'd just use a jamnut method (assuming there is enough room)
http://www.boltscience.com/pages/twonuts.htm
Min
PostPosted: Fri Apr 02, 2010 1:28 pm    Post subject: Reply with quote
Ummm....heheh, that's actually how I discovered Stage8, because of their header bolts. They are used all the time on exhaust manifolds and turbocharged applications for other platforms. Should be just fine for the 931.
PostPosted: Fri Apr 02, 2010 1:32 pm    Post subject: Reply with quote
Alrighty then, but if you are wrong, what a PITA to swap out.
Page 1 of 3
