joecitizennn
Posted: Thu Feb 11, 2010 3:08 am Post subject: 19 mpg |
| My 87 924S has always averaged between 27 to 28 MPG. Recently it has dropped to 19mpg. All services are up to date and the fuel system is spotless. I am wondering if I have a computer or sensor problem. Has anyone had a similar problem? |
Posted: Thu Feb 11, 2010 3:44 am Post subject: |
O2 or temp sensors? _________________ Toofah King Bad
joecitizennn
Posted: Thu Feb 11, 2010 12:08 pm Post subject: |
| is there a good write-up on testing these items? |
D Hook
Posted: Thu Feb 11, 2010 9:26 pm Post subject: |
Winter-blend fuel maybe? _________________ '80 924 n/a SOLD |
brupska
Posted: Fri Feb 12, 2010 12:02 am Post subject: |
| I was gonna ask where do you live?? Cold climate?? MPG will drop off from more air comming in which the car will have to mix more fuel to match!!! I don't know much about the Fuel system on the S model though. |
Posted: Fri Feb 12, 2010 2:38 am Post subject: |
The best test for an O2 sensor follows:
1. Two years old (Y/N)?
A yes to the above indicates replacement.
To avoid the Porsche parts premium, order Bosch "Universal" sensor, #15725. Got mine on E-Bay for $20. _________________ Toofah King Bad
joecitizennn
Posted: Fri Feb 12, 2010 3:50 am Post subject: |
I was told that it was winter grade fuel by other people too, but that cant be the case because my 1988 924se which has been getting a steady 20mpg is now getting 25mpg after I did a full service including vacuum lines and breather tubes. And that is with winter grade gas.
Thanks for the tip on the 02 sensor. |
Posted: Fri Feb 12, 2010 4:13 am Post subject: |
Did you use a kit for your hose service? _________________ Toofah King Bad
Posted: Fri Feb 12, 2010 10:57 am Post subject: |
Odometer slipping?
Different tires?
Is the inside of your tail pipe all covered with black carbon? _________________ White 87 924S "Ghost"
Mav666
Joined: 16 May 2008 Posts: 47 Location: Newcastle, UK
Posted: Sun Feb 14, 2010 1:42 am Post subject: |
| Paul wrote: |
Is the inside of your tail pipe all covered with black carbon? |
Mine has been of late does this signify something specific on the S? |
brupska
Posted: Sun Feb 14, 2010 1:47 am Post subject: |
| Lots of carbon on a tailpipe just means that your car is running rich. Something is making your car burn more fuel then it is supposed to. |
Posted: Sun Feb 14, 2010 7:22 am Post subject: |
Fuel with 10% ethanol tends to cause the oxygen sensor to read slightly leaner and therefore the efi system will increase the amount of fuel to compensate.
Might be worth checking next time you get fuel. _________________ Stefan
Mav666
Posted: Mon Feb 15, 2010 8:59 am Post subject: |
| I do run it on Shell 99 every now and again, and when I do it does seem to run richer |
