neophite
Posted: Wed Feb 10, 2010 4:05 am Post subject: rough idle |
| I jumped on a project that was beyond my skills. Replaced waterpump, head gasket, new plugs and wires, distributor cap, rotor.etc..It took me months since I had to redo it several times. Finally got it together and it was excited when it actually cranked and ran. Problem is at idle it runs extremely rough.It was fine before I took it apart.I checked and the timing on the crank and cam are dead on as well as the balance shafts.Any suggestions on my next course of action? Any help will be greatly appreciated. |
Posted: Wed Feb 10, 2010 4:43 am Post subject: |
Motor mounts??? _________________ erstwhile owner of just about every 924 variant ever made |
neophite
Posted: Thu Feb 11, 2010 3:16 am Post subject: |
Thanks for the reply. I have read every thread concerning rough idle and
motor mounts seem to be the logical answer. However, there was no problem before I began the repairs and the engine seems to be dropping in rpms. Is there some way to check the mounts or do you think it is a problem in the ignition system? |
masterdave
Posted: Thu Feb 11, 2010 5:16 am Post subject: |
| if the rpms are dropping or changing then it may not be the motor mounts. I had some low idle issues, it ended up being the throttle housing it is very sensitive almost in a bad way. Play around with it a bit, use the idle adjust screw to finesse it. you may find it was just set to low and the engine could not idle correctly |
minnesotamatt
Joined: 02 Dec 2009 Posts: 16 Location: woodbury minnesota
Posted: Tue Apr 27, 2010 2:47 pm Post subject: |
| how do you adjust the idle speed? my idle is very rough also and it seems like its gonna just die sometimes |
bcblase
Posted: Wed Apr 28, 2010 7:15 am Post subject: |
You have one of three problems -
1. Throttle body leak - reseal kit is cheap. (www.paragon-products.com)
2. Vacuum leak, replace with silicone lines. (www.lindseyracing.com or www.paragon-products.com)
3. MAS resistor strip is worn, reset/move wiper arm (www.clarks-garage.com or www.frwilk.com)
I did all of these just to be sure, as well as replaced: motor mounts, throttle position sensor, and a few other things...
Idles and runs smooth as silk now... _________________ 1987 Porsche 924S - track toy
Posted: Wed Apr 28, 2010 11:09 am Post subject: |
Hook up a vacuum gauge and tell us what the needle does at idle
Check the engine grounds (underneath the heater control valve)
Do a compression check
Check your firing order
Make sure the rotor set screw is tight _________________ White 87 924S "Ghost"
minnesotamatt
Posted: Wed Apr 28, 2010 3:09 pm Post subject: |
| ok thanks guys ill get ahold of a vacuum gauge and run some tests and tell you guys how it goes |
