4g63 in a 924
19779244g63
PostPosted: Fri Sep 25, 2009 10:10 am    Post subject: 4g63 in a 924 Reply with quote
hey i am planing to put a 4g63t into my 1977 924 has any one done this or thought about it give me some feed back on what u think i will post the swap if any one is intrested
my lug nuts require more torque than your makes
PostPosted: Wed Sep 30, 2009 9:23 am    Post subject: Reply with quote
You'll need a bellhousing, clutch, flywheel and motor mounts.
Depending on the length of the available bellhousings you may need to shorten the torque tube and/or weld an adapter in place. Luckily they are steel and while unweidly they aren't impossible to modify.
Since you have an early car, the torque tube isn't the strongest, nor does it have a common clutch spline so you'd be better off upgrading to a newer tube from a 924 turbo, 924s or 944 with the matching transmission.
then you have to get the engine to fit in the engine bay (clearing the steering rack, crossmember, etc) This might require altering the hood, firewall, engine bay or oil pan.
After all of that work, you still have to sort the electrics.
924OZY
PostPosted: Fri Jan 29, 2010 4:49 pm    Post subject: Reply with quote
4G63 is good,
but a 4G63T, from a VR4 or Early evo is even better,
People still put the 4G63T rods into the 4G93T's from the later model Evo's, because they are stronger, and handle more power and revs.
924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
4.0L ef Fairmont, 3000rpm stall, shift-kit, J3 chip, 3" exhaust, self tuned using tunerpro, soon to be boosted,
expecting 350Kw at wheels at 10psi.
powaw
PostPosted: Mon Feb 08, 2010 11:19 am    Post subject: Reply with quote
It will be alot of work, but don't let that stop you. I'm in the middle of putting a Audi 5 pot turbo into my 944. It needs to be something that you will enjoy doing though, its going to take a while. Good luck!
currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
future: audi I5 20VT
follow Nina at Nina's 20VT
