frankros924
Joined: 14 Sep 2007 Posts: 29 Location: Sacramento California
Posted: Fri Nov 27, 2009 9:10 am Post subject: Flushing out the coolant system, can anybody help |
Hi
I want to flush out my coolant system on my Porsche 924s 1987,
I would like to do the radiator separate from the engine block, if possible
Can anybody help me, on this procedure with the 924s.
I see these flush kits at walmart. that hook up to a garden type hose.
thank you. |
masterdave
Posted: Fri Nov 27, 2009 10:58 am Post subject: |
| you can stick a hose right in to the flange at the top of the engine block. Just disconnect the main intake tube and the out tube and flush it, same deal with the radiator, if you want to save the money you dont need any fancy adapters how ever im sure it would make the job a bit cleaner. |
bcblase
Joined: 23 Oct 2007 Posts: 574 Location: Winchester, VA
Posted: Thu Dec 03, 2009 12:25 pm Post subject: |
Do yourself a favor, and don't "power flush" your system - that is a sure way to damage something on a 22+ year old car and the cooling system.
Just drain it normally and refill with fresh phosphate-free coolant/water solution. Even Wal-Mart has the phosphate free stuff now. $11/gallon.
Brad _________________ 1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver |
mehall
Joined: 15 Dec 2008 Posts: 191 Location: Richmond, MO
Posted: Tue Feb 02, 2010 3:28 pm Post subject: |
Why phosphate free coolant?
And...have I damaged my engine?
I have no idea what the POs have used, but I've currently got the Walmart cheap stuff ($9/gal). _________________ Mark
'87 White 924s manual
'94 Lexus LS400
www.kcws.org |
joecitizennn
Posted: Wed Feb 03, 2010 4:10 am Post subject: |
| It makes the aluminum less prone to buildup from minerals and contaminants in the water. That said, here in america we dont have as much problem with high mineral content in our water and you dont hear much about the need for phosphate free antifreeze. Probably most of the used porsches you see running around have been running regular antifreeze most of their lives and are just fine. So dont fret. |
JayZzzz4
Joined: 23 Sep 2008 Posts: 544 Location: Milwaukee, WI USA
Posted: Wed Feb 03, 2010 4:55 am Post subject: |
Go to Clark's Garage. He has a whole writeup how to drain/fill under "garage shop manual"
http://www.clarks-garage.com/ _________________ White 1987 Porsche 924S manual |
