windwaiver
Posted: Sat Jan 30, 2010 5:25 am Post subject: warm start - testing in tank fuel pump |
Ok, how do you test the in tank fuel pump. I have tried the full throttle start technique and it works sometimes. Seems like it is starving for fuel, If i manually actuate the CSV (pushbutton mod) prior to cranking, it starts, but real slow. Still fighting the beast. _________________ 77.5 924 NA
81 924 na (great parts car)
82 924 NA
87 944S this is gonna cost
00 K1200LT
If i had a nickel for everytime I screwed up....... |
Joined: 29 Jul 2001 Posts: 9131 Location: Royal Oak, MI, USA
Posted: Sun Jan 31, 2010 11:03 pm Post subject: |
I've gotten the impression the in-tank pump is more for high-flow needs... but anyway...
I figured mine was bad when it would barely make any noise. I disconnected the external pump to cut down on noise, then jumped the relay - result, not much. To confirm, I then removed the outlet hose and again applied power - no improvement in the flow of fuel.
When I removed it, the cause was clear - it was heavily caked with either mud or rust.
Of course, sometimes an ohmmeter/multimeter will show a problem if there's a break etc...
HTH... _________________ Vaughan Scott
windwaiver
Posted: Mon Feb 01, 2010 2:34 am Post subject: |
thanks, still fighting the warm restart problem, car isn't worth anything when its hard to start until it cools off enough for the WUR. Least thats what it seems like. I can start it with the pushbutton mod most of the time. _________________ 77.5 924 NA
82 924 NA
00 K1200LT
windwaiver
Posted: Mon Feb 01, 2010 7:52 am Post subject: |
Ok heres what I know, any help out there of a past similar problem would really help.
The timing on the car says it is supposed to be set at 0 deg +-1deg. With it set to the spec, my vacuum is at 10#s. Setting the timing up to approx 12 I get 14 to 15 #s vacuum. Which means way more power.
I performed a leak down test of the engine and found all cylinders within 10% all around 13% leakage. All timing marks are lined up correctly, I have checked this too many times. I just ordered some new vacuum lines, (replaced most of them already) going to install silicone lines. _________________ 77.5 924 NA
82 924 NA
00 K1200LT
