brake troubles
the_mad_electrician
PostPosted: Sun Jan 24, 2010 4:21 am    Post subject: brake troubles Reply with quote
I was going to bleed my front brakes because the pedal was still spongy after replacing the rear cylinders and bleading them. I took the wheels off and the bleeder screws are completely rounded off. Any ideas? There were also some salad bowl looking dust covers, are these factory? I took them off.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
CorsePerVita
PostPosted: Sun Jan 24, 2010 5:25 am    Post subject: Reply with quote
Time for a bleed of the system, adjust your drums, and time for new bleeder screws.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Sun Jan 24, 2010 9:28 am    Post subject: Reply with quote
careful removing the bleed screws. Someone rounded them off probably from overtightening.
I snapped 2 off the first time I did my brakes.
PostPosted: Sun Jan 24, 2010 10:05 am    Post subject: Reply with quote
The salad bowls are not factory and not required or recommended.
PostPosted: Sun Jan 24, 2010 10:11 pm    Post subject: Reply with quote
There's also a very good possibility that your brake hoses need replacing too.
PostPosted: Sun Jan 24, 2010 10:12 pm    Post subject: Reply with quote
Forgot to add, it shouldn't be hard to find suitable replacement bleeders at your local parts store, once you get the old ones out.
All hail the mighty vice-grips!
the_mad_electrician
PostPosted: Mon Jan 25, 2010 5:45 am    Post subject: Reply with quote
Thanks for the help, I figured those salad bowls where not factory, I had never seen anything like them before. They were just a good place for black widows to hide!
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Mon Jan 25, 2010 6:41 am    Post subject: Reply with quote
Do a searsh on the web for speed bleeders there bleed screws that have a one way check valve in them all you need to do is loosen them and pump the pedal.
