Rear end? transmission?
Goto page Previous  1, 2
PostPosted: Sat Jan 23, 2010 8:00 am    Post subject: Reply with quote
Oh, yeah, didn't connect the dots on the TDI swap.
At 200 BHP, you will be JUST FINE with either of the stock 931 gearboxes. The thing you will want to be aware of is that the G31 does not have bell housings at either end, and the torque tube is shorter. The Audi unit has a relatively standard bellhousing up front, in that the bolt pattern apparently matches several audi lumps, from what little I've read in the hybrid/swap forums. Obviously, the driveshaft up front will be in the same position regardless of which tube you use, but the question will be how to interface the TDI engine to the torque tube. Will the bell housing be beneficial or not? Can't help you with that one, but I can take measurements if you'd like, as I have one spare of each on the bench.
PostPosted: Sat Jan 23, 2010 8:01 am    Post subject: Reply with quote
Don't know what Rasta wants for his, but they routinely sell for $800-$2000 depending on condition, mileage, and history. Quite a spread.
newman931
PostPosted: Sat Jan 23, 2010 8:04 am    Post subject: Reply with quote
ha
to be quite honest, the way the 1.9 TDI gets up and moves a jetta at 90HP - (a car almost 1000lbs heavier than mine) - i am thinking i'd be quite pleased somewhere between 150 and 175HP. ya know...
it will be ALOT quicker than it was.!
v8carreragts
PostPosted: Sat Jan 23, 2010 8:31 am    Post subject: Reply with quote
The 016 should handle the torque without any problem. The problem with pushing the rear pinion bearing through the casting is from high torque drag race starts. There is a fix for this if you are interested. It's fairly easy to do.
These transaxles are used in GT40 kit cars and although they aren't the strongest, they handle quite a bit. They also hold up to V8 conversions as well. The 951 and 944 S/S2 are the strongest (unless you can find one from a 951S) They have third gear splinded to the pinion shaft where all other 016's are heated and pressed on.
newman931
PostPosted: Sat Jan 23, 2010 8:54 am    Post subject: Reply with quote
hey cool!
v8carreragts - your the guy ideola was referring to.
do you have any idea what the deal is with the gear ratios on the turbo diesels being higher and how to set up a complimentary set up????
yeah, after reading about the GT40 kit trannys i figured i'd be alight in the torque category.
and yes! i will be very interested in the high torque fix.
thanks!
Rocco R16V
PostPosted: Sat Jan 23, 2010 9:06 am    Post subject: Reply with quote
newman931 wrote:
"In stock form the 016 will push the rear support bearing through the center section @ 300 ft/lbs of torque. The 5th gear will strip shortly thereafter. Many people with high horsepower 5 cylinders (500+) can shred teeth on gears 1-3 with a full throttle launch."
Is this a vendor trying to get work, or what????
yes i think so.
Some awd audi 5cyl turbos in the 400ft/lb + have broken these trans DRAG RACING! not street or track but at the drag strip is where they break.
they are strong enough for your needs .
"Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan
Rocco R16V
PostPosted: Sat Jan 23, 2010 9:12 am    Post subject: Reply with quote
about the bellhousing, look what this guy did.
http://www.hybrid9s.com/showthread.php?t=48
take a fwd trans bellhousing grind off what you dont need and make an adapter that bolts to the bellhousing and is welded to the torquetube, use the clutch, starter, ect from VW.
HTH
Ronald Reagan
newman931
PostPosted: Sat Jan 23, 2010 9:45 am    Post subject: Reply with quote
ROCCO!
yes!
exactly!
v8carreragts
PostPosted: Sat Jan 23, 2010 11:39 am    Post subject: Reply with quote
The difference in the diesels is the ring and pinion ratio. They use a 4.556 ratio. There are a few different ratios available for 2-5 but 1st is always the same. (3.60 except for the 951 and 944S /S2 which is 3.50)
As far as the gear they are all the same width, material, and helix between all 016 transaxles.
Here is a link for the transaxle strengthening plate.
http://stweb.peelschools.org/sssweb/TTI-WEB/cars/pictures/AudiTransaxleUpgradeStepbyStep/index.html
newman931
PostPosted: Sun Jan 24, 2010 5:05 am    Post subject: Reply with quote
so how can one change the ring and pinion ratio to 4.556?
is that just transplanting the ring and pinion from the diesel?
if so, do you got one of those tutorials around?
sorry if that's a stupid question.
love the tutorial on the strengthening plate!
thanks.
v8carreragts
PostPosted: Sun Jan 24, 2010 10:38 am    Post subject: Reply with quote
You would just change the ring and pinion to the 4.556 set. This isn't easy as you need to disassemble the transaxle and set up the new gear set. The 016 isn't an easy one to do. The procedure is in the factory manual.
Page 2 of 2
