rear window heat stip
windwaiver
PostPosted: Tue Jan 19, 2010 11:38 pm    Post subject: rear window heat stip Reply with quote
ok my connector is off, anyone know what type of adhesive to use to repair it?
77.5 924 NA
81 924 na (great parts car)
82 924 NA
87 944S this is gonna cost
00 K1200LT
If i had a nickel for everytime I screwed up.......
PostPosted: Wed Jan 20, 2010 2:00 am    Post subject: Reply with quote
I assume you mean the spade connector pulled off the glass? Since it needs to conduct - I soldered mine back on. You might need to use a goodly bit of flux, after a thorough cleaning/degreasing, to ensure a good bond.
avaconirl
PostPosted: Wed Jan 20, 2010 2:05 am    Post subject: Reply with quote
please be careful doing it like this i tried it once on a different car . the screen shattered about 30 sec's after.Maybe there is a metallic glue that will do this. P.S. it was a french car maybe the scrrn was not a thick?
PostPosted: Wed Jan 20, 2010 3:10 am    Post subject: Reply with quote
Silly French car, winters are for German cars!
Tiny
PostPosted: Wed Jan 20, 2010 3:29 am    Post subject: Reply with quote
yes agreed french are flimsily made. i soldered mine btw. works good now.
tiny
Slam
PostPosted: Wed Jan 20, 2010 3:53 am    Post subject: Reply with quote
Believe it or not, JB Weld works for this. I haven't done it myself, but years ago my (then) mechanic did this on my RX-7.
'84 944 - kid blew motor
'83 944 - resting comfortably. For 12 years
'87 944 - sideswiped by trucker
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably
MattN
PostPosted: Wed Jan 20, 2010 3:57 am    Post subject: Reply with quote
I've just been using JB weld for something else, and it says on the pack that it won't conduct electricity.
1981 924 N/A
