windwaiver
Posted: Tue Jan 19, 2010 11:38 pm Post subject: rear window heat stip |
ok my connector is off, anyone know what type of adhesive to use to repair it? _________________ 77.5 924 NA
81 924 na (great parts car)
82 924 NA
87 944S this is gonna cost
00 K1200LT
If i had a nickel for everytime I screwed up....... |
Joined: 29 Jul 2001 Posts: 9118 Location: Royal Oak, MI, USA
Posted: Wed Jan 20, 2010 2:00 am Post subject: |
I assume you mean the spade connector pulled off the glass? Since it needs to conduct - I soldered mine back on. You might need to use a goodly bit of flux, after a thorough cleaning/degreasing, to ensure a good bond. _________________ Vaughan Scott
avaconirl
Posted: Wed Jan 20, 2010 2:05 am Post subject: |
| 924RACR wrote: | | I assume you mean the spade connector pulled off the glass? Since it needs to conduct - I soldered mine back on. You might need to use a goodly bit of flux, after a thorough cleaning/degreasing, to ensure a good bond. |
please be careful doing it like this i tried it once on a different car . the screen shattered about 30 sec's after.Maybe there is a metallic glue that will do this. P.S. it was a french car maybe the scrrn was not a thick?  |
Posted: Wed Jan 20, 2010 3:10 am Post subject: |
Silly French car, winters are for German cars!  _________________ Vaughan Scott
Tiny
Posted: Wed Jan 20, 2010 3:29 am Post subject: |
yes agreed french are flimsily made. i soldered mine btw. works good now.
tiny _________________ *****1981 - 924 - Auto - London, UK****** |
Slam
Posted: Wed Jan 20, 2010 3:53 am Post subject: |
Believe it or not, JB Weld works for this. I haven't done it myself, but years ago my (then) mechanic did this on my RX-7. _________________ '88 944 Auto - may or may not resurrect |
MattN
Joined: 25 Mar 2008 Posts: 34 Location: Manchester England
Posted: Wed Jan 20, 2010 3:57 am Post subject: |
I've just been using JB weld for something else, and it says on the pack that it won't conduct electricity. _________________ 1981 924 N/A |
