elitejaso
Posted: Wed Jan 06, 2010 11:38 pm Post subject: Help: Dont wanna pay a ton for an Impulse Sender |
Hey guys,
Basically I need to find a working impulse sender (flywheel sensor) for my car or I'll be doomed to take the bus forever
The part 931.606.021.00 is NLA and could only find them on two sites: auto atlanta & german dismantlers.
However these guys want $400 for it
If anyone has one lying around or a wrecked 81 turbo that might have one please let me know and i'll be willing to pay at least $200 for one.
Cheers
Jason _________________ 1981 924 turbo (daily driver) |
stevekat
Posted: Thu Jan 07, 2010 12:35 am Post subject: |
You can probably buy an entire parts car for the $400 here in the U.S. These things are becoming pretty hard to come across. This would be the ideal item for a group buy/alternative part. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Posted: Thu Jan 07, 2010 12:52 am Post subject: |
I just received a non-functional crank sensor from 924RACR in a bin of parts I'll be going through and posting for sale later. I also have a good spare unit on the shelf that is NOT for sale (sorry, have to have a backup for my S2!). The plan is to hopefully identify between these two units a way to find or reproduce a replacement. _________________ erstwhile owner of just about every 924 variant ever made |
Vince Ponz
Posted: Thu Jan 07, 2010 1:07 am Post subject: |
When will you guys learn. Auto Atlanta keeps screwing you guys but yet you want to buy from them. Sometimes I think you deserve to get beat.
NO AUTO ATLANTA. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
stevekat
Posted: Thu Jan 07, 2010 1:13 am Post subject: |
Dan, my guess is the mechanical configuration/packaging is the challenge rather than electrical aspects. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Posted: Thu Jan 07, 2010 1:22 am Post subject: |
That's my thought as well. It can't be that hard. If it's nothing more than a bracket at the flywheel and the connector at the DITC... _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Jan 07, 2010 1:24 am Post subject: |
I don't have my factory service manual with me at work. Can somebody check and post what the diagnostic process is for checking the pulse sender? _________________ erstwhile owner of just about every 924 variant ever made |
stevekat
Posted: Thu Jan 07, 2010 1:45 am Post subject: |
Figure just need the business end, though an entire cable would be nice. Assume the business end could be spliced into the existing cable in the event of a pick up failure.
Sensor #: 931-606-021.00
Manual says: Check current flow between terminals 15 and 13, and also between 15 and 14, with a buzzer. This is the middle pin on the sensor connector (15) to each of the outboard pins (13 and 14 respectively.) Replace flywheel sensor if there is a break.
Handwritten notes in my factory manual say:
"Unit should generate between 1.0 to 2.5 volts at cranking speed."
"New unit measures 9.4 to 9.6 ohms...13 + 14"
Interpret handwritten notes as you can. Not sure if last note means measure resistance between terminals 13 and 14, or between 13 and 15, and also between 14 and 15, respectively. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Thu Jan 07, 2010 2:30 am Post subject: |
dan is this the refrence mark sensor.that your looking for info for?its in the back and picks up its referance from a bolt on the flywheel? there is also a speed sensor on the same bracket? _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Posted: Thu Jan 07, 2010 3:54 am Post subject: |
| DOCO wrote: | | dan is this the refrence mark sensor.that your looking for info for?its in the back and picks up its referance from a bolt on the flywheel? there is also a speed sensor on the same bracket? |
DOCO, on the 931, it's different than the 2.5L motor. The 924S/944 motor has both a crank reference and speed sensors. the mounting arrangement and geometry of those units are somewhat different, not to mention the pigtail end of it.
I'll take some pix of the 931 unit later tonight for reference. _________________ erstwhile owner of just about every 924 variant ever made |
