How to paint your toolbox
PostPosted: Fri Dec 18, 2009 10:55 am    Post subject: How to paint your toolbox Reply with quote
Materials needed:
1. Degreaser wax remover.
2. 400-600 and 800 grit wet - dry sandpaper & masking tape.
3.primer red or grey & white base if your using bright colors.
4. color paint & clear coat
Sand with 400 & 600 grit then degrease followed by 800
grit and another degrease & wipe down with a lint free cloth.
mask off things you dont want painted & prime & let dry.
Lightly sand with 800 grit before applting color & let dry
Mask off first color if doing a 2 tone paint scheme like
I did applying light color first. I like to pull my tape when
things are still wet if I can (less chance of tearing or
pulling paint.
Scorpio
PostPosted: Fri Dec 18, 2009 1:17 pm    Post subject: Reply with quote
hahaha..very nice joe..personalising yr toolbox!..love it!
1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!!
JayZzzz4
PostPosted: Fri Dec 18, 2009 2:12 pm    Post subject: Reply with quote
Very cool man, looks good!
White 1987 Porsche 924S manual
PostPosted: Sat Dec 19, 2009 9:39 am    Post subject: Reply with quote
Almost ready to add some tools and then
i can play with the nuts and bolts, though for those
that use zoom i did have some wrinkling of paint after
putting on the clear ill address that after it dries with
some wet sanding. Seems the new paint these days
does that alot. Im guessing the chemicals have to
cure out first.
PostPosted: Sat Dec 19, 2009 11:03 am    Post subject: Reply with quote
Joe, you're one colorful character, man. You never cease to amaze
PORSCHEV
PostPosted: Sat Dec 19, 2009 12:26 pm    Post subject: Reply with quote
Joes924Racer wrote:
Amost ready to add some tools and then
cure out first.
The reason your having trouble with wrinkling is that your using lacquer primer. Try going to a better quality urethane based primer. It is 2 part like the clear. I find Morton is a good brand for your money.
1978-#53 "D" track racer.
PostPosted: Sat Dec 19, 2009 1:22 pm    Post subject: Reply with quote
the samething happend to my airboat i had
to resand the whole thing. And the nuggets
dropped one tonight in new orleans.
PostPosted: Tue Dec 22, 2009 11:23 am    Post subject: Reply with quote
Added draw liners. Ised a lot of mastic or vinyl glue to hold down the liners. Coverd the the liner with it
completly set it in place then used a 4" putty knife to remove excess these liners wont be going anywhere.
PostPosted: Tue Dec 22, 2009 11:30 am    Post subject: Reply with quote
Nice. What about little pillows and blankets to keep them really snug at night?!
PostPosted: Tue Dec 22, 2009 3:09 pm    Post subject: Reply with quote
No a big stack with rollers would be nice.. gotta budget somewhere and
my hobbies is where.
PostPosted: Mon Dec 28, 2009 1:29 pm    Post subject: Reply with quote
Tools cleaned and ready to be organized on the tool box.
PostPosted: Tue Dec 29, 2009 3:01 am    Post subject: Reply with quote
wow ! very nice.
PostPosted: Wed Dec 30, 2009 3:40 pm    Post subject: Reply with quote
Yes I think Im ready to start tinkering again. After I
get back from the Rose bowl.
Imafordguy
PostPosted: Fri Jan 01, 2010 4:05 pm    Post subject: Reply with quote
Wrinkling is the result of incompatable products like porschev stated, or in heavy application. When paint is applied to heavy or to "wet" the solvents that thin it down pool up below the surface and the top glazes over. The Solvents with no place to go, now attack the previous coats which causes wrinkling.
Also another cheater way to go is over reduce a little clear and spray it over the primer job before the first coat of color. Its like a 7-9to1 ratio, thats like 7 parts reducer to 1 part clear. It works like a sealer... Works with laquer or two stage systems... All of them ppg thru diamont thru sikkens thru valspar... and so on. I've sprayed them all!
It will fill alot of sand scratches and help promote adhesion.
I also agree with porschev Morton is a good product for the buck, and would do you so much better than a laquer.
I'm testing a new metal etch high build primer on a project right now... Its not a morton product, and its a litttle cheaper. I hope I don't regret it!
81 Porsche 924
84 Porsche 944(parting it)
66 Ford f100
66 AC cobra kit car(major project)
64 ford f100 (429 SCJ)
62 Studebaker golden hawk gt
61 baja bug (with bad opel 1.8, looking at ford 2.3 turbo to flovo)
stevekat
PostPosted: Thu Jan 07, 2010 12:58 am    Post subject: Reply with quote
As I recall, laquer over enamel, or enamel over laquer (or both - hard to recall) creates orange peel effect, if that is what is occurring.
I also recall that you need to do multiple coats within a short period of time, or wait until prior layers cure sufficiently. That in between can cause wrinkling or orange peel.
Very nice!
Too much free time on your hands as well!
"Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's.
