What oil weight is being run in 924S's?
Osiris
PostPosted: Mon Dec 07, 2009 1:05 pm    Post subject: What oil weight is being run in 924S's? Reply with quote
I always run 20W-50 in the summer as it reaches 85+ quite regularly and switch to 10W-30 in the winter. Does this sound okay? I guess I could run 10W-30 all year long. The manual doesn't list any specific oil weight to use.
Keep a Chevy motor in a Chevy
Keep a Porsche motor in a Porsche
Keep a Ford motor in the dumpster
'87 924S 50K miles black/black
joecitizennn
PostPosted: Wed Dec 09, 2009 4:37 am    Post subject: Reply with quote
I run 5w30 in temperatures below freezing.
Mav666
PostPosted: Wed Dec 09, 2009 5:06 am    Post subject: Reply with quote
Doesn't really get that cold over here, but on the last change I used 10/40, with the age of the car I'll probably use 20/50 next time though
bcblase
PostPosted: Wed Dec 09, 2009 8:05 am    Post subject: Reply with quote
A lot of older Porsches are running the ZDDP enhanced oils. Zinc Dialkyl-Dithio-Phosphate (ZDDP) was used in oil up until the late 80's and then removed because of environmental concerns. You can't run ZDDP in newer cars because of the advanced catalytic converters, but it is recommended for older cars like the 924S.
Brad Penn and a couple of other racing oils have it already. And there are several commercially available additives that can be added to regular API rated motor oils.
FWIW, I run Castrol 10w30 year 'round. I am going to start adding a product called "ZDDP Plus" with the next oil change, or switch over to Brad Penn oil (the green stuff).
Just type "ZDDP" into Google and you'll get all the info you need.
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
joecitizennn
PostPosted: Wed Dec 09, 2009 10:26 am    Post subject: Reply with quote
I used valvoline VR1 for its ZDDP for a while, but switched to Valvoline full synthetic. I have been so pleased with the results I use nothing else, outside of mobil 1.
Using Valvoline full synthetic, my engine oil turns only slightly amber in 3000 miles. It is so clean you can see light through the stream when it is draining. The magnet on the oil plug is always clean too. I remember when running standard oil there would be a grey smudge on the magnet at oil changes. not now
Portporschedon
PostPosted: Fri Dec 25, 2009 10:30 pm    Post subject: Reply with quote
After reading posts on the unsuitability of modern oils for older cars, due to a reduction in ZDDP, I am now using the recommended weight of oil, but for diesel engines.
I mentioned this to a local mechanic and he just said " yep.....that s right!".
The car is in regular daily use with mixed long and short journeys and the only thing I have noticed is that my oil consumption has decreased.
By the way....Merry Christmas!
White 1983 924 - Renovated to near original condition and my daily driver
Dolomite 1986 924S - Coming to the end of a 4 year refurbishment.
Life is not a rehearsal
Andre'
PostPosted: Sat Dec 26, 2009 8:45 am    Post subject: Reply with quote
Great suggestion! Just switched over to Brad Penn myself on the 993, and will switch over on the 924s. Strongly suggested on all engines with only 2 valves, which utilize stronger valve springs vs. 4 valve engines. ZDDP will also reduce wear when starting the engine at start-up in the morning, or when engines are started up after an longer period of time! I'm using 20W50 but you're located farther North so 10W30 or even 5W30 should be all right.
Andre'
jrrhdmust
PostPosted: Fri Apr 02, 2010 10:37 pm    Post subject: Reply with quote
Amsoil 5w30 for me year round....
67 Mercury Cougar XR7 under Restoration
71 VW Superbeetle Completed Resto 11/07
73 Mustang Mach 1 10 Year old restoration
ic932
PostPosted: Sat Apr 03, 2010 5:20 am    Post subject: Reply with quote
I use cheapo halfords..the one that says for modern fuel injected cars. I think its the turqoise coloured one? Oil pressure gauge seems to like it.
bcblase
PostPosted: Sat Apr 03, 2010 11:14 am    Post subject: Reply with quote
Do you still have to buy Amsoil through a local "dealer"? I didn't know it was still around - I used it back in the '80s. I think it was one of the first true synthetic oils?
Brad
ic932
PostPosted: Sat Apr 03, 2010 11:22 am    Post subject: Reply with quote
Brad
Why would you use synthetic oil in a non- turbo application? Is this just money to burn?
jrrhdmust
PostPosted: Tue Apr 20, 2010 11:02 pm    Post subject: Reply with quote
Absolutely disagree.
I am a gear head big time. Synthetic not only reduces temperatures of the engine, but reducing friction, thereby reducing wear, but it also has a better additive package to reduce internal corrosion. Synthetic is also a lot more resilient to temperature spikes.
Lets say you over heat your car. If you run dino oil at 290 degrees for 5 minutes you have now lost 10 percent of the viscosity of the oil. For every minute over 300 with dino oil you loose 10 percent.
Yes it is more expensive, however since i have now pulled apart the 924s, a Ford 351C, a Ford 289 and a Harly Evo. There is a HUGE difference between the wear and corrosion on the internals of the engine between synthetic and dino.
John
PostPosted: Wed Apr 21, 2010 4:02 pm    Post subject: Reply with quote
Keep in mind that like organic food, the meaning of synthetic when it comes to engine oil has been changed to include hydro-cracked oils.
Hydro-cracked oils are just natural oils that has been refined an extra step over other natural oils.
If you're going to step up to synthetic (and you should for motors you truly care about) then do some research on how your oil of choice is made before doing your shopping.
jrrhdmust
PostPosted: Thu Apr 22, 2010 10:37 pm    Post subject: Reply with quote
+1 Absolutely correct, this comes from a court case between Mobil 1 and Casterol (I think), where Casterol is marketing Hydro-cracked oil as sytnthetic. The judge said that the oil was altered from its original state, so they could market hydro-cracked oil as synthetic.
Also, beware of synthetic blends. A lot of time it is a hydrocracked blend, but also they can call it a blend if there is any synthetic in it.
Browar
PostPosted: Mon May 10, 2010 4:20 am    Post subject: Reply with quote
What about 924 S in EU?
At the moment my car runs Mobil 1 5W50.
Browar
eS
924 S `87
