fan problems
methos76
PostPosted: Sat Sep 26, 2009 8:15 am    Post subject: fan problems Reply with quote
hi there i hope someone can help,i have an 87 924s ive replaced the waterpump, timing belt, balancer belt,thermostat,sensor in radiator,relay behind dash and still my fan wont kick on till the needle gets to the begining of the red area.everything else on car works fine does anyone have a clue,also only the pass.side fan comes on when you turn on air and only the drivers side fan comes on when the needle gets to the red.please help thank you.P.S. i refer to this car as the other hole in my wallet
PostPosted: Sat Sep 26, 2009 8:25 am    Post subject: Reply with quote
Welcome to the board.
If you have no other signs of overheating relax, my car has done the same for a long time.
methos76
PostPosted: Sat Sep 26, 2009 9:27 am    Post subject: Reply with quote
it doesnt boil over or act retarded when you start it after driving for awhile i shut it off start it right back up with no problem. i just dont want to screw it up i have dumped a bunch of money in this car.thank you
PostPosted: Sat Sep 26, 2009 11:44 am    Post subject: Reply with quote
Replacing the combo gauge for another reason did not fix mine, perhaps the temp sensor in the head next?
methos76
PostPosted: Sat Sep 26, 2009 11:52 am    Post subject: Reply with quote
where is the sensor in the head located at?
PostPosted: Sat Sep 26, 2009 12:16 pm    Post subject: Reply with quote
Under the intake manifold runners near cylinder 1.
bcblase
PostPosted: Wed Oct 07, 2009 10:53 am    Post subject: Reply with quote
Get a lower temp thermostat - the stock one clicks at like 92 deg C. You can get one that clicks at a lower temp. I originally had an 87 deg C thermostat in my 924S.
The thermostat is the same part used in many other make of cars.
1987 Porsche 924S - track toy
2001 BMW 325xi - daily driver
joecitizennn
PostPosted: Wed Oct 07, 2009 10:39 pm    Post subject: Re: fan problems Reply with quote
I guess you are aware that this car has two thermostats? One mechanical located in the waterpump, and one that is actually a thermostat-fan switch located at the upper left hand (seated in car) corner of the radiator.
bcblase
PostPosted: Thu Oct 08, 2009 11:56 am    Post subject: Reply with quote
Clarification - the thermostat/fan switch on the top of the radiator comes in different temp ranges.
Brad
PostPosted: Fri Oct 09, 2009 1:26 pm    Post subject: Reply with quote
Both the thermofan switch in the radiator AND the thermostat in the waterpump are available in at least three heat ranges.
methos76
PostPosted: Sat Oct 10, 2009 2:27 am    Post subject: Reply with quote
thanks guys i love this forum my 87 924s is coming right along
