924 CIS problems
Wiz-PORSCHE-924
PostPosted: Wed Sep 23, 2009 8:50 am    Post subject: 924 CIS problems Reply with quote
My friend has an 81 924 and is having a problem hopefully u guys can help.
Problem is ...
The car starts idles fine but lacks power when gas is given unless someone stands at the motor and lifts up the small plate under the fuel distributor. What could be bad ? The fuel pressure is good .
1987 Porsche 944
1978 Porsche 924
1992 Mercedes-Benz 190E
1988 Saab 900 (RIP)
Martijnus
PostPosted: Wed Sep 23, 2009 9:12 am    Post subject: Reply with quote
could be an air leak.
that plate you mention regulates fuel pressure by the amount of air flow (which pushes the plate up, and the lever on which it is connected).
So either the counter balance weight is gone (unlikely ), or not all the air going in the engine passes past the plate (which means there's a leak beyond the fuel distributor thing).
could be lots of other things, because it's clear that it doesn't get enough fuel.
Could be the injectors, could be the fuel distributor, could be the filter...
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Wed Sep 23, 2009 9:17 am    Post subject: Reply with quote
To add to this- the air flow is the air going into the throttle body ie vacuum.
Any leaks in the air induction or vacuum lines reduces the vacuum needed to lift the air plate.
Martijnus
PostPosted: Thu Sep 24, 2009 12:06 am    Post subject: Reply with quote
Could be I don't understand you right, but it's the flow and NOT the vacuum which lifts the plate... so if there's a leak after the plate, there's just less flow past the plate...
datatrain
PostPosted: Thu Sep 24, 2009 7:31 am    Post subject: Reply with quote
I'd be taking a serious look at the rubber boots on the plate and manifold end. Could be cracked. And yes it's vacuum on the top of the plate to lift it. The flow is the result of the pressure differential.
'78 924 NA with Collector plate
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR
Wiz-PORSCHE-924
PostPosted: Thu Sep 24, 2009 11:45 am    Post subject: Reply with quote
I have updated information on this.
**Pressure Readings**
Cold- 25lbs 1.7 BAR
Warm- 65lbs 4.5 BAR
Valve Closed 75 lbs 5.0 BAR
RPM loss is above 3,000 RPM
The Warm-up regulator is new
1987 Porsche 944
1978 Porsche 924
1988 Saab 900 (RIP)
PostPosted: Thu Sep 24, 2009 3:35 pm    Post subject: Reply with quote
Not having a vacuum guage connected I cant tell you if the pressure is +ve or -ve at the throttle body.
I can tell you it is less than normal atmospheric when the engine is running hence it sucks the air in past the plate. The resultant flow/mass of air lifts the plate.
Press down on the pedal, opens the TB, allows more flow.
Any vacuum hose leaks will affect this.
PostPosted: Thu Sep 24, 2009 9:48 pm    Post subject: Reply with quote
OK, the pressure readings are good to see, as well as to confirm that the WUR is new.
So, back to some basics - have you checked flow pattern on the injectors? Also, has the fuel filter been replaced? Is the flow direction correct (though more commonly a problem on turbos)?
Wiz-PORSCHE-924
PostPosted: Sat Sep 26, 2009 10:22 am    Post subject: Reply with quote
Ok All the rubber is good and no cracks. Now he said he advanced the timing slightly and said it made it a little better but the problem is stil there.
1987 Porsche 944
1978 Porsche 924
1988 Saab 900 (RIP)
PostPosted: Sat Sep 26, 2009 9:37 pm    Post subject: Reply with quote
Hmmm... so what is he running for timing, and has anyone set the mixture?? Or idle?
If you lift the plate and it runs better, that means it's running lean. For an NA - Turbo would be the other way round (as the plate drops, not raises, in the airflow).
