methos76
Posted: Sat Sep 26, 2009 8:15 am Post subject: fan problems |
| hi there i hope someone can help,i have an 87 924s ive replaced the waterpump, timing belt, balancer belt,thermostat,sensor in radiator,relay behind dash and still my fan wont kick on till the needle gets to the begining of the red area.everything else on car works fine does anyone have a clue,also only the pass.side fan comes on when you turn on air and only the drivers side fan comes on when the needle gets to the red.please help thank you.P.S. i refer to this car as the other hole in my wallet |
Posted: Sat Sep 26, 2009 8:25 am Post subject: |
Welcome to the board.
If you have no other signs of overheating relax, my car has done the same for a long time. _________________ White 87 924S "Ghost"
methos76
Posted: Sat Sep 26, 2009 9:27 am Post subject: |
| it doesnt boil over or act retarded when you start it after driving for awhile i shut it off start it right back up with no problem. i just dont want to screw it up i have dumped a bunch of money in this car.thank you |
Posted: Sat Sep 26, 2009 11:44 am Post subject: |
Replacing the combo gauge for another reason did not fix mine, perhaps the temp sensor in the head next? _________________ White 87 924S "Ghost"
methos76
Posted: Sat Sep 26, 2009 11:52 am Post subject: |
| where is the sensor in the head located at? |
Posted: Sat Sep 26, 2009 12:16 pm Post subject: |
Under the intake manifold runners near cylinder 1. _________________ White 87 924S "Ghost"
bcblase
Posted: Wed Oct 07, 2009 10:53 am Post subject: |
Get a lower temp thermostat - the stock one clicks at like 92 deg C. You can get one that clicks at a lower temp. I originally had an 87 deg C thermostat in my 924S.
The thermostat is the same part used in many other make of cars. _________________ 1987 Porsche 924S - track toy
joecitizennn
Posted: Wed Oct 07, 2009 10:39 pm Post subject: Re: fan problems |
| methos76 wrote: | | ive replaced the waterpump, timing belt, balancer belt,thermostat,sensor in radiator,relay behind dash |
I guess you are aware that this car has two thermostats? One mechanical located in the waterpump, and one that is actually a thermostat-fan switch located at the upper left hand (seated in car) corner of the radiator. |
bcblase
Posted: Thu Oct 08, 2009 11:56 am Post subject: |
Clarification - the thermostat/fan switch on the top of the radiator comes in different temp ranges.
Brad _________________ 1987 Porsche 924S - track toy
Posted: Fri Oct 09, 2009 1:26 pm Post subject: |
| Both the thermofan switch in the radiator AND the thermostat in the waterpump are available in at least three heat ranges. |
methos76
Posted: Sat Oct 10, 2009 2:27 am Post subject: |
| thanks guys i love this forum my 87 924s is coming right along |
