Druman
Joined: 19 Mar 2007 Posts: 419 Location: Middleport, Ohio
Posted: Sun Sep 20, 2009 4:14 pm Post subject: Brake warning light issue |
My warning light keeps coming on, and I don't know why. I just had my pads changed last year and they are still really thick. Anyone have any ideas?
7osh _________________ 87' 924S non-sunroof (Red) 45K miles
85' 944 "early" NA (Red) 130K miles
PORSCHE pisses excellence... |
Posted: Sun Sep 20, 2009 11:24 pm Post subject: |
Have you checked the switch and wiring at the hand brake?
Is your master cylinder reservoir full?
How's the wiring look at the master cylinder?
Do you have a lot of travel on the brake pedal? _________________ White 87 924S "Ghost"
Druman
Posted: Mon Sep 21, 2009 12:54 am Post subject: |
Hey Paul, thanks for replying.
I think it might help if I knew exactly what the light was suppose to indicate.
The set up I have has 3 lights, one for brake fluid (left) one for seatbelt (bottom) and one for what I think is brake pads (right). The one for brake fluid isn't coming on, and I've checked my fluids so I know that's fine. The handbrake has a separate light right above my "low fuel" light.
So I'm guessing that it is some sort of sensor issue?
Posted: Mon Sep 21, 2009 1:12 am Post subject: |
In the 924NA and 931 (and assuming the 924S is the same), the center console brake light is also tied into the oil pressure warning. -So if oil pressure is low (or if there's an oil pressure sender problem (grounding)), both the oil and brake lights turn on. -But if your oil light is burnt out, obviously you'll only have the one brake light.. Check the oil pressure light with ignition switched on, but engine not started - all dash warning lights should light. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Mon Sep 21, 2009 1:51 am Post subject: |
I wonder if he is asking about his 944 on a 924 board without telling us..... _________________ White 87 924S "Ghost"
Druman
Posted: Mon Sep 21, 2009 7:15 am Post subject: |
Oh, sorry. Yeah I'm talking about my 944 I didn't think it made much difference. I know I have a bad ground/connection somewhere, because sometimes my oil pressure light, brake fluid light, and brake pad light, all flash together and random times. I've never been able to trace that issue tho.
