Posted: Thu Sep 17, 2009 9:32 pm Post subject: X-Post: Custom A arms |
These popped up the other day on Pelican. VERY interesting! Although, I would only be interested if they can be made to accommodate the sway bars. But nice looking alternative, and priced right too (when compared to the other aftermarket alternatives or new-from-Porsche).
http://forums.pelicanparts.com/showthread.php?t=498907
| modenas wrote: | Custom set of a arms for you guys and gals out there that like mods. well here a good one for the price. it will fit the last and early cars. will take the big break setup if you have one on your car, and the ball joint is simple to replace if needed. 825 shipped and any questions please ask.
_________________ erstwhile owner of just about every 924 variant ever made |
Scorpio
Posted: Thu Sep 17, 2009 10:43 pm Post subject: |
They look very nice Dan, but what exactly makes them superior? im guessing some slight weight savings?..not sure if theyde be worthy of the $825 shipped tag, or did he miss a decimal there? _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
Posted: Thu Sep 17, 2009 11:00 pm Post subject: |
| Scorpio wrote: | | They look very nice Dan, but what exactly makes them superior? im guessing some slight weight savings?..not sure if theyde be worthy of the $825 shipped tag, or did he miss a decimal there? |
Lighter wieght, stronger (newer) alloy (according to the seller), quick-swappable from early-to-late offset, rebuildable balljoint (not all alu arms are rebuildable), no alu ball joint socket to bind (common failure point on the factory alu arms), upgraded castor block design, and reversible orientation on the ball joint pin for ride height adjustment (instead of having to run longer pins like the ones I'm using).
New alu arms from Porsche are stupid expensive (they weren't made to be rebuildable). And the aftermarket alternatives for serious race applications are $1600 a pair. That makes these look like a bargain, and he's reduced the price to $725 a pair. For the average street car, particularly with early setup, rebuilding early steel arms will be cheaper. But these appear to be a really nice alternative for serious track applications. _________________ erstwhile owner of just about every 924 variant ever made |
Scorpio
Posted: Thu Sep 17, 2009 11:04 pm Post subject: |
well i cant really comment as i have next to no experience on the issue of a-arms...except for the fact that i drilled out rivets from my old ones and bolted in new ball joints, oh and welded some brackets for the bar thingy
Sounds like you know what youre talking about so make like Nike and..Just do it..  _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Posted: Thu Sep 17, 2009 11:48 pm Post subject: |
i'd love a set...but 825...what the hell? for that money i can get a complete late 951 suspension..front and rear.
i'd be willing to pay a maximum of 300 euros for a set...shipped. _________________ Supercharger and EFI kits
Posted: Thu Sep 17, 2009 11:56 pm Post subject: |
Comparing apples to oranges. _________________ erstwhile owner of just about every 924 variant ever made |
Rocco R16V
Posted: Fri Sep 18, 2009 6:01 am Post subject: |
Those are very cool! _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
Min
Posted: Fri Sep 18, 2009 9:26 am Post subject: |
My problem with these arms is there is no way to know what kind of actual engineering went into designing and producing them, they are highly modified rx7 a-arm's, but did the person making them do any sort of testing on them? load analysis? anything? or did he just slap a couple of cnc machined bits onto a rx7 a-arm and call it good?
Posted: Fri Sep 18, 2009 10:06 am Post subject: |
Some of those questions are answered in the cross-referenced thread. To avoid the appearance of defending this product, I won't repeat it all here. I just found this to be an interesting alternative and thought I'd pass it along. _________________ erstwhile owner of just about every 924 variant ever made |
Min
Posted: Fri Sep 18, 2009 2:26 pm Post subject: |
Well, I read the whole post in the link you posted, I saw nothing that answered any of my questions. As far as I'm concerned an a-arm is a critical load bearing piece of your suspension. Even the grain of the cnc machined pieces could have an effect on the capabilities of that material. If they are cut incorrectly they will have a far smaller yield strength. I'm not trying to nitpick his product, I'm just saying, buyer beware on this one, a rx7 has completely different requirements than a 924/944 does, and unless you've done the math, you can't be sure its a safe product. I'd like to see the sellers calculations if he has done the math.
flosho
Posted: Fri Sep 18, 2009 4:50 pm Post subject: |
What math is all involved. You have to look at the overall length the a-arm extends, which is adjustable for early offset and late offset. Then if the bushings are in the same spot, as long as the A-arm sits parallel or better (meaning the outer most part of the a-arm is lower to the ground then the chassis side) then the geometry should be the same.
It looks like a nice piece of work, but the profit margin on this must be HUUUUUUUUUUGE.. I bet it doesn't cost more than $100 per side... _________________ [This Space For Rent] |
Posted: Fri Sep 18, 2009 5:53 pm Post subject: |
exactly...i dont know why he is askin that wopping 800+
if those are mazda arms then all he is asking 800+ for is that CNC part? c'mon !!
if the 800 price was to be sustained by something it would be by endless tests on this product that guarantee that it will not break and work the same or better than the stock arms...wich is not...or it appears not to be..
i've got one question...that CNC part that goes from the alu arm to the balljoing....uses two holes in the alu A arm...were the holes there in the first place or were they drilled by the guy? if they were drilled i'd be concerned about aluminium giving away there...cracking and ultimately dezastrous failure. _________________ Supercharger and EFI kits
RC
Posted: Fri Sep 18, 2009 7:31 pm Post subject: |
From a $20 ebay purchase:
And less than $50 worth of aluminium, ball joints and bolts.
To a $825 example of dubious back shed engineering:
Doesn`t look like rocket science.
Does appear to be an excellent profit margin.
Definitely do not want to be a crash test guinea pig for these. Not healthy at suburban speeds, likely fatal at highway speed and absolute suicide at Northern Territory (unlimited) speeds.
Perhaps after many years of track evaluation and road use by gamblers with a spare $800.
Only then maybe you could consider knocking some up one Sunday afternoon or getting a local machine shop to do it for a fraction of the OP`s price. |
bass gt
Joined: 02 Dec 2004 Posts: 971 Location: Johannesburg for now!!
Posted: Sat Sep 19, 2009 12:45 am Post subject: |
Guy's,
sorry but I'm with min on this one. Forget the CNC bar, you are asking the front of the car to be supported on two bolts!!! If just one fails, the other will suffer catastrophic failure quickly followed by your car suffering the same!!
These belong firmly in the trash can!!
Steve _________________ Front Wheel Drive is the Devil's work. |
flosho
Posted: Sat Sep 19, 2009 1:38 am Post subject: |
What if the CNC part followed the curve of the A arm to the rear bushing part. Then you could have it bolted in 8 or 10 spots. _________________ [This Space For Rent] |
