Late Windshield Question
mvallee
PostPosted: Mon Sep 07, 2009 11:37 pm    Post subject: Late Windshield Question Reply with quote
Who has installed a late windshield?
I know they aren't needed with the flush windshield but did you grind off the moulding studs in the windshield jam or leave them?
Thanks!
Auburn, NH
1987 Porsche 924CGT in progress
1974 Porsche 914/6 next project
1965 Alfa Romeo Spider Veloce restored
1953 Alfa Romeo 1900C Ghia Bodied Coupe project
v8carreragts
PostPosted: Tue Sep 08, 2009 9:10 am    Post subject: Reply with quote
I'm planning on using a late windshield on my 84 944. I think you will need to grind off the moulding studs to clear the glass. The early 951 had a spacer bonded to the window channel to raise the glass flush. Also the two plastic supports need to be changed to the late type so they are high enough to support the glass.
mvallee
PostPosted: Tue Sep 08, 2009 10:14 am    Post subject: Reply with quote
Thats what i figured, off they come. I have the supports and the spacer is available at Pelican 944 559 543 02.
Auburn, NH
PostPosted: Tue Sep 08, 2009 3:37 pm    Post subject: Reply with quote
the late model windshield is much cheaper than the early one...at least in my country.
Kroggers
PostPosted: Tue Sep 08, 2009 5:09 pm    Post subject: Reply with quote
I am not 100% sure, but I think you have to change the wiper arms as well...
Kroggers
CoolCavaRacing.com
1983 924 (aka Scruffy)
1978 911SC (aka Wanda)
mvallee
PostPosted: Tue Sep 08, 2009 10:23 pm    Post subject: Reply with quote
Good point, I have a pair of later wiper arms, I'll compare
Auburn, NH
v8carreragts
PostPosted: Thu Sep 10, 2009 11:50 am    Post subject: Reply with quote
The late windshields are $240 installed in my area.
mvallee
PostPosted: Thu Sep 10, 2009 12:01 pm    Post subject: Reply with quote
Thats a good price, what brand? Local shop or a chain?
Auburn, NH
v8carreragts
PostPosted: Thu Sep 10, 2009 2:00 pm    Post subject: Reply with quote
Try glass.net You get quotes from three shops in your area.
PostPosted: Thu Sep 10, 2009 8:17 pm    Post subject: Reply with quote
Same price that I paid to have an early style replaced in the 941...
v8carreragts
PostPosted: Wed Sep 16, 2009 10:58 am    Post subject: Reply with quote
I have been looking at the pieces needed for this. What was done to make up for the raised windshield was they changed the lower panel. The one that the windshield wiper assembly bolts to. On the early cars (up to '85/1) the place where the shafts go through this panel is dimpled down. On the 85/2 and newer this panel is raised in that place. Here is a page from the factory manual showing this on the late car.
[img][/img]
What I plan to do is make up two pieces of sheet metal with dimples to weld in place of the early dimples after I cut the old ones out. To make these up I will place a piece of sheet metal between a socket that fits the inside of the dimple and a pipe fitting that fits on the outside of the dimple in a vice or my hydraulic press. When you crank the vice closed it will put a dimple in the metal. You will need to measure the distance you close the vice so it is approximately the same as the one currently in the car. Then the old parts need to be cut out and the new ones welded in place, upside down.
This will raise the wiper assembly to the correct location. I have already checked the fit and the early wiper assembly will still fit after it is moved up.
You will also need the spacer piece that pushes onto the windshield pinchweld, the two lower corner pieces and the two pieces that support the base of the windshield. The original wipers should fit too.
mvallee
PostPosted: Wed Sep 16, 2009 11:35 am    Post subject: Reply with quote
The cowl and firewall is all I have left of my 951 parts car, I'll check it out and take some pics for comparison.
Auburn, NH
mvallee
PostPosted: Mon Sep 21, 2009 10:53 am    Post subject: Reply with quote
Your right, the cowl is completely different. Top pic is the 951, bottom 924S.
The wiper arms are also different.
Auburn, NH
v8carreragts
PostPosted: Tue Sep 22, 2009 10:19 am    Post subject: Reply with quote
I have been "fixing the problem on my car. Here is the beginning. Both are welded now and have roughed out bondo.
I basically made 2 sheet metal pieces, cut out the factory dimples and welded these in.
I believe the late wiper arms are different because splined part where they attach is different.
[img][/img]
thirdgenbird
PostPosted: Sat Sep 26, 2009 3:18 am    Post subject: Reply with quote
maybe this is a stupid question, but could i just fabricate a spacer to put under the wiper arm? would there be enough spline engagement? (i havent pulled them off yet.
option #2... by looking at my wipers, it looks like the issue involved without this modification would be the bottom of the wiper arm contacting the glass. could someone simply modify the arms or source new ones (a la vw) that may have the required clearance and the same spline pattern?
i know there is a 924 in "golf" guise that has a late windshield. has he modified his cowl?
17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel
