Cylinder Head
neophite
PostPosted: Thu Sep 03, 2009 2:12 am    Post subject: Cylinder Head Reply with quote
I am in the process of replacing the head gasket on my 87 924S. I realize that I will be replacing a lot of gaskets before the job is through (intake,exhaust,etc.). My question is, Do I use any type of adheisive or coating on any of these gaskets? If so, what do you suggest? I would also appreciate any other tips you may have concerning this job.
Thanks
edredas
PostPosted: Thu Sep 03, 2009 2:46 am    Post subject: Reply with quote
Nope... don't use anything. Just make sure that your surfaces are completely free of dirt and oil...
http://www.clarks-garage.com/pdf-manual/cyl-02.pdf
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
John_AZ
PostPosted: Thu Sep 03, 2009 2:17 pm    Post subject: Reply with quote
Note the 4 exhaust manifold gaskets may have 2 different sides. You place the metal side to the steel manifold side-metal to metal. The other side to the cylinder head.
Be careful of the intake manifold gaskets. Handle with care. One is different----take note.
The rear cam cork gasket. Get new locking washers for the bolts. Do not overtighten.
The head gasket. Follow the engine number torque sequence. If you have tall head "nuts" (BTW you have to buy new nuts) the sequence is 15 pounds touque--------------wait 30 minutes-------------90 degree --------------wait 30 minutes -----------------90 degrees. Do not rush the 30 minutes.
If the front cam seal is not leaking-think about doing it, many skip this step because it is a real rough job. If you do it, have a new cam bolt.
GL
John_AZ
1988 924S + 1987 924S
neophite
PostPosted: Thu Sep 03, 2009 10:43 pm    Post subject: Reply with quote
Thanks so much for the help. Looks like I will be ordering more nuts and bolts. Again, I appreciate the information.
