Joined: 29 Jul 2001 Posts: 9082 Location: Royal Oak, MI, USA
Posted: Thu Sep 06, 2007 10:09 pm Post subject: MSD 6AL installed successfully |
Just wanted to say thanks, we did the install yesterday, and it went quite smoothly, no issues, fairly quickly too! Fired right up, no worries. That diagram worked perfectly, was VERY helpful - THANKS!
We used the mag pickup as noted, stock distributor, worked very nicely. Obviously our wiring is a little different due to this being a racecar; no stock wiring still in use, MSD is wired to the kill switch, and ignition is likewise all different - now a toggle on the dash.
It went so easy, I'm almost tempted to put one in my car... (still all stock except for a Permatune CD ignition)
PS - car's going to the dyno tonight for debug (make sure we finally killed off that miss) and tuning. Engine's an old stock rebuild, not built like mine; we should get some numbers representative of a tweaked stock motor with bolt-ons only (header and race exhaust, the MSD, and otherwise very stock - though we'll be adding an offset cam key while on the dyno). _________________ Vaughan Scott
goc931
Posted: Mon Aug 17, 2009 7:53 pm Post subject: |
Pocketscience, if you are still here at the forum can you please explain if and how you managed to switch off the engine using the ignition key or if you installed a main switch, which I am using today?
In my main set up, slightly different than alexroys, the fuel pump didn't start so I have removed the relay and short wired it between the 30 and 87 contacts. Now I am only managing it manually with my racing main switch. This is not ideal since I might want to have the power on for my electrical blower and don't want to have the fuel pump working at the same time. How did you get your fuel pump relay to understand the signal from the MSD without "hanging" itself?
Any advice on these tho issues would be extremely appreciated. I have a race on Saturday the 22/8.
Best regards
Goran _________________ Porsche 924 -83, Race car
132hp, 950kg w/o driver |
Joined: 23 Apr 2006 Posts: 1650 Location: Sydney, Australia... mate!
Posted: Mon Aug 17, 2009 8:10 pm Post subject: |
Hi Goran,
I fixed it with the ballast resistor. Wired it up as-per the MSD doco and it worked a treat.
Cheers, _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
goc931
Posted: Mon Aug 17, 2009 8:16 pm Post subject: |
| pocketscience wrote: | Hi Goran,
Cheers, |
Ok, thanks for the fast answer, but what size (ohm) and between which cables? I imagine we have the same colour schemas to our cables me having a 1983 924 N/A.
I am sorry if you thought I would figure out this on my own, but I don't. I hate electrics.
Best regards
Posted: Mon Aug 17, 2009 8:34 pm Post subject: |
If you have the doco that came with your MSD check-out page 9. It has the wiring, and talks about the type of resistor - "Chrysler Dual Ballast Resistor). I don't recall the specs on it, but they are dirt cheap (<$10).
http://www.jimsautoparts.com/mopar_performance_ignition.htm
http://www.leeparts.com/mopar/electrical/ignition/resto_dual_ballast_resistor_.html
69 911 |
goc931
Posted: Mon Aug 17, 2009 8:44 pm Post subject: |
Ok, so I have to pollute the car with Chrystler components.
You are a real "Mate" thanks.
Best regards
Posted: Mon Aug 17, 2009 8:48 pm Post subject: |
| goc931 wrote: | Ok, so I have to pollute the car with Chrystler components.
Best regards
Goran |
At least it's an inexpensive exercise and only takes a few minutes to execute!
Good luck Saturday!
69 911 |
goc931
Posted: Mon Aug 17, 2009 8:56 pm Post subject: |
Sure, no morries. Just kidding.
I just have to find a dealer nearby that carry them, before Friday.
Thanks
goc931
Posted: Mon Aug 17, 2009 10:39 pm Post subject: |
Just a final clarification, did this ballast resistor also solve the fuel pump no-go problem or was it only the engine run-on problem?
If not, how did you take care of a fuel pump relay not starting the fuel pump?
Sorry for being a nuisance.
Posted: Tue Aug 18, 2009 10:12 am Post subject: |
The resistor solved the engine run-on problem. I never had an issue with the fuel pump so can't really comment. Sorry.
G. _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
goc931
Posted: Tue Aug 18, 2009 3:38 pm Post subject: |
| pocketscience wrote: | The resistor solved the engine run-on problem. I never had an issue with the fuel pump so can't really comment. Sorry.
G. |
Wow, but our cars should look the same and should have similar issues.
Can you please in short explain your connections to the known wires in an MSD unit and your 924 N/A? I am pretty in to it now so you don't have to draw any schemas.
Do you use the magnetic pickup and violet/green cable (my setup) or the white cable from MSD for ignition signal?
What have you done with the std coil + -side green/white(wire1) and violet/clear(wire2)? Are they still together and both connected to the red MSD cable (my setup)?
What about the std coil - -side black(wire1) and green (wire2)? Are they still connected together and then...how are the connected? I have separated them and don't use the black for anything and the green (rev wire) is connected to the tach output connection on the MSD box.
Do you still use the Bosch ignition box or have you removed it completely?
Mine is gone since I didn't see any difference in behaviour and it doesn't add any functionality (I have heard) to the setup. The MSD is taking over the ignition length and power.
Does it show I'm getting desperate?
Best regards
Posted: Tue Aug 18, 2009 4:32 pm Post subject: |
OK, it was a while ago when I hooked it all up. Will try get to the garage tonight and spec it out. I'm not using the white line, only the green/purple - I know that much. My Bosch box was sitting there for months, but I eventually removed it completely. Didn't notice any change in behavior when it came out.
I didn't do anything funky, or beyond was was documented by MSD - and it started first go and I haven't thought about it since quite honestly...
69 911 |
goc931
Posted: Tue Aug 18, 2009 4:43 pm Post subject: |
| pocketscience wrote: | OK, it was a while ago when I hooked it all up. Will try get to the garage tonight and spec it out. I'm not using the white line, only the green/purple - I know that much. My Bosch box was sitting there for months, but I eventually removed it completely. Didn't notice any change in behavior when it came out.
G. |
You are a lucky one.
Seems like same-same but different behaviour.
I'll be awaiting your details with great anticipation.
Two more things,
1. Do you use any tach adapter, then pressumably the MSD 8920 since you use the green/purple magnetic pickup cable?
2. Do you use the std fuel pump relay?
Best regards
Posted: Thu Aug 20, 2009 7:59 am Post subject: |
Hi,
No tach adaptor - again just hooked up the tach output form the MSD and it worked. Also I'm using the stock FP relay - didn't touch that at all.
The orange from MSD goes straight to the + terminal on the coil - nothing else is connected to that point.
The thin black from MSD goes straight to the - terminal on the coil - nothing else is connected to that point.
The previous coil connections are simply connected together - very much like the earlier diagram.
The tach output from the MSD connects to the existing green/black wire running to the tach. In my case this also runs to the MegaSquirt.
Good luck!
69 911 |
goc931
Posted: Thu Aug 20, 2009 8:20 am Post subject: |
Thanks pocketscience
That is clear to me now.
I've got a funny noise from the back of the car (fuel pump?) when I connected the tach output from MSD to the black/green combo cable when the ignition was off, so I thought there must be something fishy there and removed it. I should maybe investigate more about it since that is the only thing different in our set-ups.
I have bought and installed the ballast resistor but don't dare to start the car to try it out. It is 15 minutes past midnight here.
Tomorrow will be the day.
I am also planning to use the oil pressure sensor to manage the fuel pump/relay in some way.
Thanks again mate.
