Posted: Wed Aug 12, 2009 3:57 am Post subject: |
Nice job porschev.. You dont drive it enuff. _________________ 1979 porsche 924 Na
weekend_warrior
Joined: 14 Jul 2009 Posts: 42 Location: Hayden, Idaho
Posted: Thu Aug 13, 2009 6:31 am Post subject: |
| She sure is a beaut. |
PORSCHEV
Posted: Thu Aug 13, 2009 10:06 am Post subject: |
Thanks guys. _________________ 1976 924
1978-#53 "D" track racer. |
Chrenan
Posted: Thu Aug 13, 2009 1:43 pm Post subject: |
Looks excellent! _________________ 1987 951 - M193 Version for Japan |
Posted: Fri Aug 14, 2009 3:03 am Post subject: |
What did you use to cut in the corners thinking a 3" or 4" round
cutting wheel. _________________ 1979 porsche 924 Na
Last edited by Joes924Racer on Fri Mar 05, 2010 12:09 pm; edited 1 time in total |
PORSCHEV
Posted: Fri Aug 14, 2009 9:37 pm Post subject: |
I used a 2 inch zip wheel to cut around the corners of the headlight covers. Also you just slowly grind at the surface, rather then penetrating the wheel into the metal.
The car is almost ready for the road....Just have to figure out 2 wiring issues and I can go for antique inspection. Highbeam relay only works sometimes .....wipers keep blowing the fuse. _________________ 1976 924
Rich H
Posted: Fri Aug 14, 2009 9:45 pm Post subject: |
Looks  _________________ 1994 Lotus Esprit S4 - Work in progress...
ZODIAC
Joined: 08 Apr 2009 Posts: 342 Location: West Haven, Ct
Posted: Mon Oct 12, 2009 9:04 pm Post subject: |
looks really good!
what is the degree of difficulty doing something like this? i really want the GT headlight look, but dont know if i could do a good job of it.  _________________ "Kraut cars, they know how to build 'em".
1977 924 N/A - Red with waterdamage interior
yes...waterdamage is now a color... |
Posted: Sun Dec 27, 2009 2:18 am Post subject: |
Did you make a post on the making of the 6mm plexi material covers. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
PORSCHEV
Posted: Sun Dec 27, 2009 9:20 pm Post subject: |
The way I did the plexi covers was clamped the over sized plexi onto the steel headlight covers as tight as I could. Then heated it over my wood stove in my shop. As the plexi would heat I would tighten down the claps a bit more until it was uniform with the steel cover. Then cool it and remove the clamps. Trace the headlight covers shape onto the plexi and trim.
You need a lot of clamps and for best results put a piece of wood to make a bigger clamping surface otherwise you will get visible pressure points into the plexi surface. _________________ 1976 924
Posted: Mon Apr 12, 2010 5:20 am Post subject: |
This post deserves a Cheers. A Hammerhead Lemon smoothie
with vanila or cocoanut in the sunshine.
You molded the headlight backs after you cut the box. Ace work
big boy. _________________ 1979 porsche 924 Na
