Fuel Distributor Check Valve
Chrenan
PostPosted: Mon Aug 10, 2009 12:37 am    Post subject: Fuel Distributor Check Valve Reply with quote
Does anyone have the part number for the check valve in the fuel distributor for a 1980 CIS setup?
Me and Doodle were chatting yesterday and I realized when I went through my fuel system, I replaced the check valve at the pump, but not the one that screws into the fuel distributor. For some reason, I can't find the part number for the fuel distributor check valve in PET.
Any ideas?
Duncan
PostPosted: Mon Aug 10, 2009 1:52 am    Post subject: Reply with quote
Do you mean the system pressure regulating valve?
I thought you should only change the small rubber ring on the valve, not the whole valve?
stevekat
PostPosted: Mon Aug 10, 2009 7:31 am    Post subject: Reply with quote
Here is the page/part from EBS Racing. I recently ordered this kit from them and it solved my hot start problem.
My o-ring had a chunk out of it. Probably in some instances can get away with just replacing the o-ring.
Not particularly cheap for the kit.
This comes up when I searched for my 1981 931, might want to double-check for the 1980 and if yours is an na.
http://www.ebsracing.com/ShopByVehicle.epc?q=1981-PORSCHE-9--4--/--L4--1983cc--.0l--Gas--Fi--Turbo-Fuel--Injection&yearid=1981%40%401981&makeid=PORSCHE%40%40PORSCHE%40%40X&engineid=1263282%40%40924++%2F+L4%2D1983cc+2%2E0L+GAS+FI++Turbo%40%40924&catid=Fuel+Injection%40%40Fuel+Injection&subcatid=Fuel+Metering+Valve+Parts+Kit@@Fuel+Metering+Valve+Parts+Kit&mode=PA
"Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's.
stevekat
PostPosted: Mon Aug 10, 2009 7:35 am    Post subject: Reply with quote
Double-check the application for your year and model - the one below is for a 1981 931.
PostPosted: Mon Aug 10, 2009 7:40 am    Post subject: Reply with quote
Talking about the little fella that's built into the fuel pressure regulator?..
I usually see it referred to as "push up valve".
It serves as a check valve to block flow and prevent pressure loss from the WUR back to the tank on shutdown.
Ya, I would think all you need is an o-ring kit at $1-$2.
