Newgoalie27
Joined: 25 Nov 2007 Posts: 16 Location: Shiloh Illinois
Posted: Sat Aug 08, 2009 4:05 am Post subject: Setting the Idle on a 77. |
So I've finally gotten my calipers back from the re-builders installed them and they seem to be working. Meanwhile we've been trying to get the car to run and it wouldn't keep Idle and felt like it was running on 3 cylinders. turns out one spark plug wasn't threaded in so we had an escapade trying to get that to go in. We just got it in and started the car up it sounds good when you give it a little gas and get it to 2000rpm but when you let off the gas the rpm drops to a rock to around 200 or so... Could It be bad gas? (the cars been sitting for a few years but we've drained the tank and put some new gas in) I was wondering how to set the idle to help the car run a little better and clear any possible bad gas from the fuel lines.
Come on I know some of you guys know how to do this. _________________ My to do list:
1965 Mustang fastback
1977 Porsche 924 NA no turbo
Hey if I get my brakes working and fix the Lower rocker panel and the drivers side damage from when the guy who had it before me slid off the road this could be my first car  |
Posted: Sat Aug 08, 2009 5:33 am Post subject: |
Haynes, pgs. 87-88. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Newgoalie27
Posted: Sat Aug 08, 2009 7:58 am Post subject: |
We don't have the haynes manual yet but we just ordered one.
It starts but as soon as I let go of the key it dies _________________ My to do list:
Posted: Sun Aug 09, 2009 11:38 am Post subject: |
There is a screw on the throttle body just above the vacuum hose going to the dissy.
Unscrewing this will raise the revs but there is a lot to having the motor running right besides having the revs up. _________________ Porsche 924 1984 (UK import) NA
Posted: Sun Aug 09, 2009 6:16 pm Post subject: |
theres also an online haynes manual on this site somewhere.
or parts of it. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Newgoalie27
Posted: Mon Aug 10, 2009 6:48 am Post subject: Fuse for Fuel pump |
Ive tried adjusting the idle with no avail so I've averted my attention towards the fuel system. Im currently trying to find out if my fuel pump is working properly and was wondering which fuse goes to it? or is it a relay box? (it looks as though there are 2 empty spaces.) _________________ My to do list:
Posted: Mon Aug 10, 2009 7:54 am Post subject: |
you will have to look at valve timing, ign timing, fuel pressures and air/fuel mix.
its very possible vacuum lines are shot, fuel filter blocked or fuel pickup in the tank blocked.
The air induction into the throttle body can get cracked.
Bad leads plugs rotor dissy cap or coil.
Electricals get corroded.
Its a matter of working through one system at a time. have fun. _________________ Porsche 924 1984 (UK import) NA
oldgoaly
Posted: Mon Aug 10, 2009 10:46 am Post subject: |
A little bit of an update, engine starts quickly, dies 2-3 seconds after starting, holding in the "new" hot start fix button allows the engine to limp along for a few more seconds. I'm not used to FI, SU, webbers, deorttos look simple compared to the fuel distributor.
Grounds we have been cleaning every ground we can find, many of the lights and electrical items now work!
With all the reading in the last few days, we look to be having a fuel issue, Does one need to purchase the K-jetronics fuel pressure test kit, or can one make a nice reliable one from???
Vacuum lines what do you guys recommend? white hoses look fine, those short connector hoses are sloppy, i did put some white petroleum jelly to help fill in a little with damaging anything.
My wanting to set up the idle is a carb idea, get it running an see what the Sun machine says. old habits.....
A little history on car we have had it a few years, it was given to me by a gentleman in town who described the "hot start problem" to a tee. The tank had a small amount of gas with stablizer, but wasn't as clear as could be, it has been drained, a few fresh gallons have been added, the "screen/filter" has been removed and cleaned, new fuel filter has been installed, lines were flushed, pump move allot of fuel! the injectors had been removed and cleaned by previous owner.
We learn more after the Haynes manual gets here but experience with them says there will be things not covered very well. Thanks for your time and help! tt |
Posted: Mon Aug 10, 2009 5:43 pm Post subject: |
It sounds like the pump works when cranking but stops when you release the key which would give you a few seconds of running.
Fuel pump relay or wiring? _________________ Porsche 924 1984 (UK import) NA
oldgoaly
Posted: Tue Aug 11, 2009 7:24 am Post subject: |
Fuel pump relay is located where????
tt |
Posted: Tue Aug 11, 2009 7:56 am Post subject: |
drivers side- fuse panel. on most its the top row 2nd from left
Normal relays will not work here. If you jumper pins 30 and 87 the pump should run for testing. _________________ Porsche 924 1984 (UK import) NA
oldgoaly
Posted: Tue Aug 11, 2009 9:42 am Post subject: |
| Thanks Ozzie, I owe you a pint of the golden liquid! make that a couple of them! tt |
oldgoaly
Posted: Tue Aug 11, 2009 10:02 am Post subject: |
| just went out a tried to pull it out, seems like we may have some corrosion, this relay has a fuse on top? (bad shoulder/knees) can't see it to well. tt |
D Hook
Posted: Tue Aug 11, 2009 11:31 am Post subject: |
They're a sunofabitch to get out. I usually pull the one right below it so I can get a grip on it. (Just did one about 30 minutes ago.) I also take the onboard screw out of the aux. fuse panel just above the relays and rotate it away to get a better grip.
I believe the early cars had a fuse on the relay. _________________ '80 924 n/a SOLD |
Newgoalie27
Posted: Wed Aug 12, 2009 1:17 am Post subject: |
| D Hook wrote: | I usually pull the one right below it so I can get a grip on it.
What one right below it?
The one right below it is missing.... Is it the one for the A/c unit?
I cleaned up the contacts on the fuel pump relay, popped the cover off everything looked fine so i put it back togther and stuck it back in the car turned it over... guess what... car cranked over like always started ran for a seccond or two then dropped to about 200 rpm for maybe 10 seconds and died. So there must be something up with the wiring or grounds...
Which is in the back of the car along with the Talights... so as far as I can tell. _________________ My to do list:
