Bucket seat?
PostPosted: Mon Aug 03, 2009 11:12 pm    Post subject: Bucket seat? Reply with quote
With that type of seat, can you still use regular seat belt or you must go to harness?
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
Chrenan
PostPosted: Tue Aug 04, 2009 12:46 am    Post subject: Reply with quote
Harness and roll bar is a minimum in my mind with a one piece bucket seat.
924-76
PostPosted: Tue Aug 04, 2009 1:13 am    Post subject: Reply with quote
Chrenan wrote:
in my mind
I understand that it work better, but it just sound shitty to lock a 4 or 5 point harness to go the convenient store one km away to get milk.
That’s why I have trying to figure if you can still use the regular one.
I’m hoping that I can pass the seat belt trough the bottom hole.
1980 931S
masterdave
PostPosted: Tue Aug 04, 2009 2:11 am    Post subject: Reply with quote
you will still be able to use regular seat belts with out a problem. they may not pass through the bottom hole but they will fit around the seat no issue. if you are looking to just put bucket seats in to replace your current seats and not for racing, you dont need harnesses if you do put them in i am interested to know which ones you used and how hard it was, as i am looking to do the same thing.
924-76
PostPosted: Tue Aug 04, 2009 2:17 am    Post subject: Reply with quote
I will keep the board update.
I’m currently looking on what is available and it might be a winter project if my budget allow.
1980 931S
Chrenan
PostPosted: Tue Aug 04, 2009 2:25 am    Post subject: Reply with quote
Those seats are designed to keep you very vertical in an accident compared to stock seats. I'd want some additional roll over protection if I'm being kept more upright in an accident, hence my suggestion to run a roll bar. Its all about personal risk tolerance. I run one piece buckets with 6 point harnesses and a roll bar. If I was to take any item out of that equation, I'd be more comfortable with the stock setup.
And buckling in takes about 15 seconds when you have done it hundreds of times, it isn't even a concern.
924-76
PostPosted: Tue Aug 04, 2009 3:11 am    Post subject: Reply with quote
Thank you for the clarification.
I will look into the roll bar also before I take my final decision.
1980 931S
Brockoli
PostPosted: Wed Aug 05, 2009 10:42 am    Post subject: Reply with quote
you can probably run the stock seat belts if you wanted to. The new 911 with the optional one piece seats run standard seat belts. The stock seat belt is run through the openings if that makes sense. You would have to unbolt the seat belt at the floor, put it through the opening and bolt it back in place. Same with the female seat belt part. Hope this makes sense, otherwise I will find pics for you. I have seen this in excellence mags.
But I do agree with Chrenan about the seat+harness=good
'80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
'79 924 Sebring Edition(Sitting)
POORscheMAN
PostPosted: Wed Aug 05, 2009 11:25 am    Post subject: Reply with quote
If your not looking at buckets for competition use, you might want to consider a Schroth 4 pt harness vs. a 5 or 6 pt.
http://www.schrothracing.com/store/Tuning/rallye/rallye-cross
They are DOT approved 4 pt harness systems with little expansion joints that work like a factory shoulder belt eliminating the need for the between the legs anti-sub belt.
The danger with a 5pt in a street car is that you might get lazy and not clip the anti-submarining belt, which makes the harness very likely to hurt you in the event of an impact.
Audi 5K Throttle Body - 10:1 comp
Stage 1 Cam -MSD coil- Crane XR700 ignition - Headers
260# springs -26mm rear TBars-
poly bushings -Weltmeister sway bars
1980 924 N/A -- stock
1982 931
1988 944
1994 968 M030
wombat
PostPosted: Wed Aug 05, 2009 4:12 pm    Post subject: Reply with quote
I had those exact seats in Grey and they worked very well with a standard seat belt for street use. I will say that this was in a totally different car but If you are careful about how you do it you can actually have both a 5 point harness for race day and the standard seatbelt for street use, just look at snap ends and wrap around ends for your 5 pt harness. This setup was what I needed to allow my car to be used as a road car and a semi serious track car as I was getting mixed opinions if a 5 pt harness was legal in a road car here and thought it better safe than sorry.
1977 924 2.0 Auto
Brockoli
PostPosted: Thu Aug 06, 2009 3:47 am    Post subject: Reply with quote
I had some time to find a pic to better explain what I was talking about.
Depending on how aggresive the shoulder area is on the seat you could do this.....
I still think you shoud do a roll bar/cage and harnesses or get a non-fixed bucket seat. Also the roll bar option looks badass!!!
PostPosted: Thu Aug 06, 2009 5:20 am    Post subject: Reply with quote
i tried some of the cheaper steel fram seats, its not something i recomend, not at all. Add some bucks and buy a fiber glass chair. I found that Cobra Imola S suited me really nice. I did mountings according to the racing regulations and put it on the stock sliding mounts, really neat. It really adds a new dimension to driving, at least if you drive at the track or auto cross. After i added a OMP lower back pillow it worked nice even for longer trips. If you choose a seat that isnt that extreme, with other words has lower sides it works ok with stock belt.
Why not adda picture of my setup
Octane
PostPosted: Thu Aug 06, 2009 12:28 pm    Post subject: Reply with quote
I put a Sparco Sprint seat in my 924. Coming from a race car background I couldn't stand a standard seat for performance driving. The car is also slowly being converted into a track/race car so I figured I might as well enjoy a nice seat in the meantime. I have one for the passenger side too whenever I get a chance to install it.
Replacing my stock seat for the Sparco...
Modified the factory sliders to mount to the Sparco, then aluminum brackets to bolt it to the floor. This is temporary until I get my real adapters/sliders.
This is how it looks installed in the car... very comfortable although a pain in the ass to get in and out of. Luckily I am 17 years old and 140 lbs so I'm fairly agile.
Seating position...
The seatbelt can and should go through the side harness hole in the seat behind the handbrake, like Porsche does factory in their GT2's/GT3's etc. I am getting a cage and harnesses put in soon so I'm not too concerned for the time being. Hope this helps and let me know if you have any questions.
- Brendan
1977 Porsche 924
Chrenan
PostPosted: Thu Aug 06, 2009 12:40 pm    Post subject: Reply with quote
My setup:
PostPosted: Fri Aug 07, 2009 8:51 am    Post subject: Reply with quote
Use a Schroth harness Rallye-cross harness and a harness bar.
That harness is DOT legal since it allows you to move around a little in the case of a roll-over, etc.
Besides they are slightly easier to put on/off.
Just keep in mind that some sanctioning bodies may not like harnesses without a substrap.
