sokol
Posted: Sun Aug 02, 2009 3:36 am Post subject: |
| powaw wrote: | sounds good. I would like to see pictures when you finish.
What are you using for a fuel pump. I was going to see if the unit from the s6 will fit into the 944 |
Fuel pump Walbro 255 litres/hours
At me still a box 6-step from А6TDI
And differential Torsen from an Audi V8
Dispersal to hundred about 5 seconds |
powaw
Posted: Sun Aug 02, 2009 8:28 am Post subject: |
Are you saying that you are using the transaxle from an A6 TDI?
How is the V8 Torsen? I might try to find one of these also. _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
future: audi I5 20VT
follow Nina at Nina's 20VT |
sokol
Posted: Mon Aug 03, 2009 7:56 pm Post subject: |
| powaw wrote: | Are you saying that you are using the transaxle from an A6 TDI?
How is the V8 Torsen? I might try to find one of these also. |
Installation - is very difficult |
powaw
Posted: Mon Aug 03, 2009 8:58 pm Post subject: |
I have read about the torsen swap. There is some work to be done, but the cost is supposed to be very cheap for one of these. I haven't checked here yet to see if the prices are true. _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
sokol
Posted: Tue Aug 04, 2009 10:37 am Post subject: |
| powaw wrote: | | I have read about the torsen swap. There is some work to be done, but the cost is supposed to be very cheap for one of these. I haven't checked here yet to see if the prices are true. |
Reducer with m8-100$
Grinding works-still 100$
The rest has made! |
Adie
Posted: Thu Aug 06, 2009 2:06 pm Post subject: |
for the throwout bearing, check out summit racing for there mcLeod one, it's been working well in my cars for many many years _________________ 924 zero cylinder race car, |
powaw
Posted: Thu Aug 06, 2009 8:33 pm Post subject: |
thanks! I will check it out. _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
