powaw
Posted: Fri Jul 24, 2009 12:35 pm Post subject: Hydraulic throwout bearing |
I'm putting the AAN motor into my 944. Anybody have any ideas on a hydraulic throwout bearing that would fit this app? Thanks. _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
future: audi I5 20VT
follow Nina at Nina's 20VT |
sokol
Posted: Sat Jul 25, 2009 2:25 am Post subject: Re: Hydraulic throwout bearing |
| powaw wrote: | | I'm putting the AAN motor into my 944. Anybody have any ideas on a hydraulic throwout bearing that would fit this app? Thanks. |
I know
But I can not correctly understand that you interests? |
powaw
Posted: Sat Jul 25, 2009 12:21 pm Post subject: |
hey! You have the 924 with the 20vt in it right? What kind of clutch release bearing are you using? How is your car doing? _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
sokol
Posted: Sat Jul 25, 2009 7:21 pm Post subject: |
| Clutch plate from an Audi 200 turbo |
powaw
Posted: Sat Jul 25, 2009 9:39 pm Post subject: |
What did you use to operate the clutch?
a clutch fork
or a slave bearing . [/img] [/img]
Can someone help me explain this? _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
sokol
powaw
Posted: Mon Jul 27, 2009 8:48 pm Post subject: |
What car did you get that from? _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
sokol
powaw
Posted: Tue Jul 28, 2009 9:43 am Post subject: |
thank you! Hopefully I can find that part or a similiar one in the states. Did you use the original radiator or fit the audi unit to you car? Have you had any overheating problems? _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
sokol
Posted: Tue Jul 28, 2009 8:44 pm Post subject: |
| powaw wrote: | | thank you! Hopefully I can find that part or a similiar one in the states. Did you use the original radiator or fit the audi unit to you car? Have you had any overheating problems? |
Greetings
Problems with an overheat are not present
Radiator from WV pasat 1.8
Having blown doubled from an Audi а6
While only an air radiator
I wish to replace on more
If there is a possibility arrive on a visit
I will show all to you and |
powaw
Posted: Wed Jul 29, 2009 12:17 pm Post subject: |
Thanks, but that is a little too far for me. If we are ever over there I will look you up though.  _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
sokol
Posted: Wed Jul 29, 2009 7:05 pm Post subject: |
| powaw wrote: | Thanks, but that is a little too far for me. If we are ever over there I will look you up though.  |
At us it is very beautiful
Many historical monuments
To stop is where) |
powaw
Posted: Wed Jul 29, 2009 8:47 pm Post subject: |
so how is your car going? Did you get the body work finished? What color are you going to paint it? _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
sokol
Posted: Sat Aug 01, 2009 6:09 pm Post subject: |
| powaw wrote: | | so how is your car going? Did you get the body work finished? What color are you going to paint it? |
Still it is a lot of work
I wish to paint in two colours of the basic yellow +black |
powaw
Posted: Sat Aug 01, 2009 10:26 pm Post subject: |
sounds good. I would like to see pictures when you finish.
What are you using for a fuel pump. I was going to see if the unit from the s6 will fit into the 944 _________________ currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, koni yellows, 968 m030 bars,,RE ball joints, full delrin
