dash16
Posted: Thu Jul 09, 2009 10:39 pm Post subject: removing intake boot |
I see all these hoses with these weird looking hose clamp type things hooked up to the intake boot
Are these hose clamps re=usable or do you just rip them off and put on regular hose clamps? They seem like they were installed with some obscure tool.
thanks. _________________ 1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS |
moorepower
Joined: 21 Dec 2006 Posts: 263 Location: Raleigh, North Carolina, USA
Posted: Fri Jul 10, 2009 7:24 am Post subject: |
They're probably the OEM crimp-on type clamp. I don't like them because they tend to loosen up a little over the years, and they can't really be tightened up. These were a source of a couple of vacuum leaks on my car.
Remove them and replace with fuel injection clamps, or a good stainless worm gear clamp of the proper size. _________________ Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways |
masterdave
Posted: Fri Jul 10, 2009 5:29 pm Post subject: |
| the clamps made assembly line assembly quicker as machines or even workers can crimp far easier, and faster than they can screw on clamps |
ronined
Posted: Mon Jul 20, 2009 2:49 am Post subject: |
If you remove them carefully, then you could possibly reuse them, but I would replace them with something more "user friendly." _________________ '87 924S |
Posted: Mon Jul 20, 2009 3:10 am Post subject: |
Use a dremel to cut off the ears. I like them, especially on small diameter hose, because they seal better than tiny hose clamps and don't need to be retightened like screw type clamps. . .handy for hard to reach areas. _________________ Toofah King Bad
