Rich H
Posted: Mon Jul 13, 2009 10:42 pm Post subject: How much is EFI kit worth? |
If I was to sell my EFI kit, how much is it really worth?
It consists of:
MS1
EDIS
Fuel rail + injectors
36-1 toothed wheels and cam sensor
Air and water temp senders
Dizzy blank
Innovate LC-1 Wideband lambda sensor + controller
Lash up AFR gauge
+ whatever wiring I can rip out.
Essentially a bolt on and wire in kit. _________________ 1994 Lotus Esprit S4 - Work in progress...
huckster
Joined: 22 Dec 2006 Posts: 115 Location: Burnaby B.C.
Posted: Tue Jul 14, 2009 4:16 am Post subject: |
I would say If you buy everything new it would cost over $1000US are you selling the fuel presure reg. and fuel lines with that ? I have bought all the parts I need for EFI and have spent alot more than $1000US _________________ 77.5 project car have never driven. burgundy
79 parts car sea foam. blue new clutch and shifter bushings
79 driver yellow new shocks water pump shifter bushings
96 ford escort sw |
Posted: Tue Jul 14, 2009 4:20 am Post subject: |
| huckster wrote: | | I have bought all the parts I need for EFI and have spent alot more than $1000US |
Really?! Do tell... _________________ erstwhile owner of just about every 924 variant ever made |
huckster
Posted: Tue Jul 14, 2009 4:36 am Post subject: |
WELL
I have msII$300
EDIS $ 100
Fuel rail& injectors and inserts $350
wideband O2 $ 300
And that is just the start wiring sensors and fuel supply and fabrication depending on how fancy you make it can cost twice that! _________________ 77.5 project car have never driven. burgundy
96 ford escort sw |
Posted: Tue Jul 14, 2009 4:54 am Post subject: |
Good to know...thanks for sharing! _________________ erstwhile owner of just about every 924 variant ever made |
Min
Posted: Tue Jul 14, 2009 4:56 am Post subject: |
which wideband o2 did you go with huckster?
huckster
Posted: Tue Jul 14, 2009 4:59 am Post subject: |
LC1 with gauge _________________ 77.5 project car have never driven. burgundy
96 ford escort sw |
Min
Posted: Tue Jul 14, 2009 5:01 am Post subject: |
| huckster wrote: | | LC1 with gauge |
Nice
Rich H
Posted: Tue Jul 14, 2009 5:28 am Post subject: |
£600 then.
Fair enough. Will have to make the call later on...
Cheers gents
Rich _________________ 1994 Lotus Esprit S4 - Work in progress...
